Ana içeriğe geç
HP 15-ay014dx Heat sink Replacement
Neye ihtiyacın var
  1. HP 15-ay014dx Heat sink Replacement, Battery: adım 1, 1 resimden 1.
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Heat sink Replacement: adım 2, 1 resimden 1.
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Heat sink Replacement: adım 3, 1 resimden 1.
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Heat sink Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Heat sink Replacement: adım 5, 1 resimden 1.
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Heat sink Replacement, Wireless Card: adım 6, 1 resimden 1.
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Heat sink Replacement: adım 7, 2 resimden 1. HP 15-ay014dx Heat sink Replacement: adım 7, 2 resimden 2.
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
  8. HP 15-ay014dx Heat sink Replacement: adım 8, 2 resimden 1. HP 15-ay014dx Heat sink Replacement: adım 8, 2 resimden 2.
    • Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
  9. HP 15-ay014dx Heat sink Replacement: adım 9, 1 resimden 1.
    • Using the size #00 Phillips screwdriver remove the single screw holding it in place.
  10. HP 15-ay014dx Heat sink Replacement: adım 10, 1 resimden 1.
    • carefully pull the card of its slot.
  11. HP 15-ay014dx Heat sink Replacement, Heat sink: adım 11, 1 resimden 1.
    • Remove the four screws holding the heatsink on.
  12. HP 15-ay014dx Heat sink Replacement: adım 12, 1 resimden 1.
    • Carefully pry the heat sink up and out of position to un-stick it from the thermal paste.
    • When reassembling, follow these steps on How to Apply Thermal Paste underneath the heatsink.
Sonuç
Drake Scoville
533 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 415
