Ana içeriğe geç
HP 15-ay052nr Screen Replacement
Neye ihtiyacın var
    1. HP 15-ay052nr Screen Replacement, Battery: adım 1, 1 resimden 1.
      • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
      • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-ay052nr Screen Replacement: adım 2, 1 resimden 1.
      • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
      • The sliders are located at the back of the device on the side where the display hinges are.
      • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-ay052nr Screen Replacement: adım 3, 1 resimden 1.
      • Pull the battery slightly up and out to remove.
      • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-ay052nr Screen Replacement, Bottom Cover: adım 4, 1 resimden 1.
      • Remove the rubber feet on the bottom of the device to access all the screws.
      • There are two rubber feet, one on each side of the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-ay052nr Screen Replacement: adım 5, 1 resimden 1.
      • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
      • Gently remove the optical drive (CD reader) to more easily separate the base.
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-ay052nr Screen Replacement: adım 6, 1 resimden 1.
      • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
      FixBot'a Sor
      Yorum Ekle
    4. HP 15-ay052nr Screen Replacement: adım 7, 1 resimden 1.
      • Separate the base of the computer from the component assembly.
      • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-ay052nr Screen Replacement, Fan: adım 8, 1 resimden 1.
      • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
      • The base is the side by the heatsink, which is made of copper.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-ay052nr Screen Replacement: adım 9, 1 resimden 1.
      • Unplug the fan cable from the motherboard.
      • The fan can now be removed.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-ay052nr Screen Replacement, Screen: adım 10, 1 resimden 1.
      • Disconnect the display cable.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-ay052nr Screen Replacement: adım 11, 1 resimden 1.
      • Unplug the wire attached to the wireless adapter.
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-ay052nr Screen Replacement: adım 12, 1 resimden 1.
      • Remove the two 6.5-mm screws from the fan side of the computer.
      FixBot'a Sor
      Yorum Ekle
    4. HP 15-ay052nr Screen Replacement: adım 13, 1 resimden 1.
      • Remove the two 3mm JIS #0 screws.
      • Remove the one broad head 2mm JIS #0 screw.
      FixBot'a Sor
      Yorum Ekle
    5. HP 15-ay052nr Screen Replacement: adım 14, 1 resimden 1.
      • Lay the display with its back on a flat surface.
      FixBot'a Sor
      Yorum Ekle
    6. HP 15-ay052nr Screen Replacement: adım 15, 1 resimden 1.
      • Pry open the screen cover using an iFixit opening tool around the entire screen.
      FixBot'a Sor
      Yorum Ekle
    7. HP 15-ay052nr Screen Replacement: adım 16, 1 resimden 1.
      • Remove the four 3-mm JIS #0 screws.
      FixBot'a Sor
      Yorum Ekle
    8. HP 15-ay052nr Screen Replacement: adım 17, 1 resimden 1.
      • Unplug the cable connected to the screen located on the bottom.
      • The screen should come off and can be replaced.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 760
