Ana içeriğe geç
HP 15-ay078nr RAM Replacement
Neye ihtiyacın var
  1. HP 15-ay078nr RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the laptop so that the underside is facing up.
    • Rotate the device so that the CD slot is in the upper left corner.
    FixBot'a Sor
    Yorum Ekle
  2. HP 15-ay078nr RAM Replacement: adım 2, 2 resimden 1. HP 15-ay078nr RAM Replacement: adım 2, 2 resimden 2.
    • Put your fingers on the battery latch.
    FixBot'a Sor
    Yorum Ekle
  3. HP 15-ay078nr RAM Replacement: adım 3, 2 resimden 1. HP 15-ay078nr RAM Replacement: adım 3, 2 resimden 2.
    • Using your fingers, push each battery latch simultaneously towards the middle.
    • This releases the battery.
    • Remove the battery from the laptop.
    FixBot'a Sor
    Yorum Ekle
  4. HP 15-ay078nr RAM Replacement, Back Panel: adım 4, 2 resimden 1. HP 15-ay078nr RAM Replacement, Back Panel: adım 4, 2 resimden 2.
    • Pull off the two rubber feet on the underside of the device.
    • Remove the twelve 9.5 mm screws from the underside of the device using a Phillips #2 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. HP 15-ay078nr RAM Replacement: adım 5, 1 resimden 1.
    • Slide an opening pick around the edges between the back panel and the rest of the device to release the plastic retention clips that hold the panel in place.
    FixBot'a Sor
    Yorum Ekle
  6. HP 15-ay078nr RAM Replacement: adım 6, 1 resimden 1.
    • Lift up on the panel to remove it completely from the device.
    FixBot'a Sor
    Yorum Ekle
  7. HP 15-ay078nr RAM Replacement, RAM: adım 7, 1 resimden 1.
    • Place your fingers on the latches that hold the RAM in place.
    FixBot'a Sor
    Yorum Ekle
  8. HP 15-ay078nr RAM Replacement: adım 8, 1 resimden 1.
    • Pull the latches apart, releasing the RAM from its holder.
    • Remove the old RAM from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
If the device does not work, you will need to make sure that the RAM sticks have equal measurements to each other, otherwise it will not work properly
Cameron Duffy
327 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S3G1
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 32
Her zaman: 555
