Ana içeriğe geç
HP 15-ay114cy Motherboard Replacement
Neye ihtiyacın var
  1. HP 15-ay114cy Motherboard Replacement, Orient the Laptop: adım 1, 1 resimden 1.
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Motherboard Replacement, Push out the Battery: adım 2, 2 resimden 1. HP 15-ay114cy Motherboard Replacement, Push out the Battery: adım 2, 2 resimden 2.
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Motherboard Replacement, Remove the Battery: adım 3, 2 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Battery: adım 3, 2 resimden 2.
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
  4. HP 15-ay114cy Motherboard Replacement, Unscrew the Back Cover: adım 4, 2 resimden 1. HP 15-ay114cy Motherboard Replacement, Unscrew the Back Cover: adım 4, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the twelve 8 mm Phillips screws that are holding down the bottom cover of the laptop.
  5. HP 15-ay114cy Motherboard Replacement, Remove the Disk Drive: adım 5, 2 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Disk Drive: adım 5, 2 resimden 2.
    • Grab a hold of the disk drive and carefully pull it away from the computer.
    • Continue to slide the disk drive out of the laptop until fully removed.
    • Due to the removal of the battery, no power is available to open the disk drive through the use of the eject button.
    • Make sure to pull out the disk drive at a 90 degree angle as demonstrated. Do not attempt to wiggle the drive out of the laptop.
    • There will be resistance when removing the drive. Mishandling may cause broken wires, which could make your disk drive inoperative.
  6. HP 15-ay114cy Motherboard Replacement, Remove the Back Cover: adım 6, 3 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Back Cover: adım 6, 3 resimden 2. HP 15-ay114cy Motherboard Replacement, Remove the Back Cover: adım 6, 3 resimden 3.
    • Place a plastic opening tool in-between the upper and lower pieces of the bottom cover.
    • Using your hands and the plastic opening tool, gently separate the cover from the frame.
    • Slowly remove the bottom cover from the base of the laptop.
    • Using metal pry tools can damage your device.
  7. HP 15-ay114cy Motherboard Replacement, Remove the Fan Screws: adım 7, 2 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Fan Screws: adım 7, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the two 8 mm Phillips-head screws that attach the fan to the base.
  8. HP 15-ay114cy Motherboard Replacement, Remove the Fan Wire: adım 8, 3 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Fan Wire: adım 8, 3 resimden 2. HP 15-ay114cy Motherboard Replacement, Remove the Fan Wire: adım 8, 3 resimden 3.
    • Using your index finger and thumb, carefully grab the wire that connects the fan to the motherboard.
    • Using a bit of force, remove the cable from the connector on the motherboard.
  9. HP 15-ay114cy Motherboard Replacement, Remove the Fan: adım 9, 2 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Fan: adım 9, 2 resimden 2.
    • Using your hand, grab one of the fan corners and pull up.
    • Carefully remove the entire fan from the base of the laptop.
  10. HP 15-ay114cy Motherboard Replacement, Remove the Heatsink: adım 10, 3 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Heatsink: adım 10, 3 resimden 2. HP 15-ay114cy Motherboard Replacement, Remove the Heatsink: adım 10, 3 resimden 3.
    • Using the Phillips #0 screwdriver, unscrew the four 2 mm Phillips-head screws that secure the heatsink to the laptop base.
    • Grasp one end of the heatsink and then carefully lift up to remove it from the laptop base.
  11. HP 15-ay114cy Motherboard Replacement, Remove the Speaker Wire Connection: adım 11, 3 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Speaker Wire Connection: adım 11, 3 resimden 2. HP 15-ay114cy Motherboard Replacement, Remove the Speaker Wire Connection: adım 11, 3 resimden 3.
    • Using your index finger and thumb, gently grasp the speaker cable and pull it from the connector.
    • Move along the speaker wire and ensure that none of the wiring is caught on other components or mounting tabs.
    • Remove the speakers.
  12. HP 15-ay114cy Motherboard Replacement, Remove the Wired Connections: adım 12, 3 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Wired Connections: adım 12, 3 resimden 2. HP 15-ay114cy Motherboard Replacement, Remove the Wired Connections: adım 12, 3 resimden 3.
    • Place your index finger on the plastic ridge of each of the seven ZIF connectors connected to the motherboard.
    • Using your index finger, flip up the black tabs on each of the connectors to release the cable.
    • Gently pull each the wired connections from the motherboard.
  13. HP 15-ay114cy Motherboard Replacement, Remove the Screws from the Base: adım 13, 2 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Screws from the Base: adım 13, 2 resimden 2.
    • Using a Phillips #0 screwdriver, unscrew the twelve 2 mm Phillips-head screws that secure the motherboard to the laptop base.
  14. HP 15-ay114cy Motherboard Replacement, Remove the Wireless Card: adım 14, 3 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Wireless Card: adım 14, 3 resimden 2. HP 15-ay114cy Motherboard Replacement, Remove the Wireless Card: adım 14, 3 resimden 3.
    • Use your index finger and thumb to gently grasp the green wireless card, then pull the card horizontally out and away from the motherboard.
  15. HP 15-ay114cy Motherboard Replacement, Remove the Audio/USB Board: adım 15, 3 resimden 1. HP 15-ay114cy Motherboard Replacement, Remove the Audio/USB Board: adım 15, 3 resimden 2. HP 15-ay114cy Motherboard Replacement, Remove the Audio/USB Board: adım 15, 3 resimden 3.
    • Use your index finger and thumb to gently grasp the display connector and remove it from the motherboard.
    • Carefully grasp an end of the motherboard and gradually lift it up and away from the laptop.
Sonuç
Bradley Evans
613 İtibar
5 adet Kılavuz yazıldı
Ekip
S20S3G#1 S20S3G#1 üyesi
Repair Café
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 401
