Ana içeriğe geç
HP 15-bs168cl Fan Replacement
Neye ihtiyacın var
  1. HP 15-bs168cl Fan Replacement, Battery: adım 1, 2 resimden 1. HP 15-bs168cl Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug your laptop from its power adapter.
    • Turn the laptop over.
  2. HP 15-bs168cl Fan Replacement: adım 2, 2 resimden 1. HP 15-bs168cl Fan Replacement: adım 2, 2 resimden 2.
    • Slide the Battery lock slider to the right until you see the “Unlocked” lock symbol.
  3. HP 15-bs168cl Fan Replacement: adım 3, 2 resimden 1. HP 15-bs168cl Fan Replacement: adım 3, 2 resimden 2.
    • Slide the Battery release slider towards the battery while pulling the battery out.
  4. HP 15-bs168cl Fan Replacement, Fan: adım 4, 2 resimden 1. HP 15-bs168cl Fan Replacement, Fan: adım 4, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the six 10.5 mm screws visible on the bottom of the laptop.
  5. HP 15-bs168cl Fan Replacement: adım 5, 2 resimden 1. HP 15-bs168cl Fan Replacement: adım 5, 2 resimden 2.
    • Carefully peel the four rubber feet off the bottom to reveal the four hidden screws.
    • Use a Phillips #1 screwdriver to remove the four 10.5 mm screws.
  6. HP 15-bs168cl Fan Replacement: adım 6, 1 resimden 1.
    • Remove the DVD drive by carefully sliding it out.
  7. HP 15-bs168cl Fan Replacement: adım 7, 3 resimden 1. HP 15-bs168cl Fan Replacement: adım 7, 3 resimden 2. HP 15-bs168cl Fan Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Flip the laptop over and open the screen.
    • Carefully use a flat plastic card to separate the bottom plastic shell from the main body of the computer. Slowly slide the plastic card around the computer in between the two halves of its casing.
    • Flip the computer back over and remove the bottom plastic shell.
  8. HP 15-bs168cl Fan Replacement: adım 8, 2 resimden 1. HP 15-bs168cl Fan Replacement: adım 8, 2 resimden 2.
    • Using a Phillips #1 screwdriver remove the screw from the Wi-fi card.
    • Remove the card.
  9. HP 15-bs168cl Fan Replacement: adım 9, 2 resimden 1. HP 15-bs168cl Fan Replacement: adım 9, 2 resimden 2.
    • Carefully unplug the LCD connector using a plastic spudger.
  10. HP 15-bs168cl Fan Replacement: adım 10, 2 resimden 1. HP 15-bs168cl Fan Replacement: adım 10, 2 resimden 2.
    • Unplug the power connector.
  11. HP 15-bs168cl Fan Replacement: adım 11, 3 resimden 1. HP 15-bs168cl Fan Replacement: adım 11, 3 resimden 2. HP 15-bs168cl Fan Replacement: adım 11, 3 resimden 3.
    • Pull all three cables to the side to reveal the 6.7 mm screw attached to the fan.
    • Remove the screw with a Phillips #0 screwdriver.
    • Unplug the fan connector.
    • Pull out the fan carefully leaving the heatsink in place.
Sonuç
Christian Puga
340 İtibar
2 adet Kılavuz yazıldı
Ekip
UC Santa Barbara, Team S3-G3, Nowak Fall 2019 UC Santa Barbara, Team S3-G3, Nowak Fall 2019 üyesi
UCSB-NOWAK-F19S3G3
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 693
