Ana içeriğe geç
HP 15-db0015dx Battery Replacement
Neye ihtiyacın var
  1. HP 15-db0015dx Battery Replacement, Battery: adım 1, 2 resimden 1. HP 15-db0015dx Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
    How can I remove the rubber strips? Which screwdriver head should I use?
    Alex Watkins - Yanıt
  2. HP 15-db0015dx Battery Replacement: adım 2, 3 resimden 1. HP 15-db0015dx Battery Replacement: adım 2, 3 resimden 2. HP 15-db0015dx Battery Replacement: adım 2, 3 resimden 3.
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
    The top of what? Note that iFixit does not like arrows, and this arrow doesn’t seem to make sense here when you’re lifting up. Instead, use a flipbook style shot to show this action. I would also separate out the yellow bullet to a new step so you have three images to show this process, and also, so you can add more details to the description of what to do.
    I believe the tool here is the spudger, which you have in the tool list as well. Make sure to correctly identify tools.
    I suggest that you remove the CD-DVD drive BEFORE removing the back cover.
    Michael Maxson - Yanıt
  3. HP 15-db0015dx Battery Replacement: adım 3, 3 resimden 1. HP 15-db0015dx Battery Replacement: adım 3, 3 resimden 2. HP 15-db0015dx Battery Replacement: adım 3, 3 resimden 3.
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
    What is the orange highlighted section? You want the text and images to work independently. The picture also seems to contradict what you say, since your hands are on the sides. Reminder: remove arrows in all pictures in favor of action shots.
    Add warning and info bullets to let the audience know that they may damage other sections of this computer by pulling pieces off.
    Alec Diaz - Yanıt
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Dobrej schanim zakladovou desku na HP Pavilion 15-db005dx Palmrest ,
Mohli bysta mi poradit kde ji koupim predem dekuji za odpoved.
jiri Zavurka - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 56
Son 30 gün: 165
Her zaman: 7,132
