Ana içeriğe geç
HP 15-f004dx RAM Replacement
Neye ihtiyacın var
  1. HP 15-f004dx RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Flip laptop over to the back, so that the stickers are showing and the RAM panel is facing up.
    FixBot'a Sor
  2. HP 15-f004dx RAM Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #0 screwdriver to unscrew the two 2mm RAM shield screws from the bottom of the laptop.
    FixBot'a Sor
  3. HP 15-f004dx RAM Replacement: adım 3, 3 resimden 1. HP 15-f004dx RAM Replacement: adım 3, 3 resimden 2. HP 15-f004dx RAM Replacement: adım 3, 3 resimden 3.
    • Remove the RAM shield.
    • Small brackets secure the RAM. Push the brackets to the side to free the RAM.
    FixBot'a Sor
  4. HP 15-f004dx RAM Replacement: adım 4, 2 resimden 1. HP 15-f004dx RAM Replacement: adım 4, 2 resimden 2.
    • The RAM card should now pop up out of its slot. Remove the RAM.
    • Next, you will replace/reseat the memory modules following steps 3 and 4 in reverse. Once you have completed that, you can now power on the computer to test and see if reseating/replacing the RAM has resolved the problem.
    FixBot'a Sor
Sonuç
1Rehber Yorum
Cuánto es el maximo de ram permitido para este modelo? Estoy pensando en ampliarlo a 8 o 16
Christian Gutierrez - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 74
Her zaman: 1,132
