Ana içeriğe geç
HP 7 Plus 1302 Charging Port Replacement
Neye ihtiyacın var
  1. HP 7 Plus 1302 Charging Port Replacement, Back Cover: adım 1, 1 resimden 1.
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Charging Port Replacement: adım 2, 2 resimden 1. HP 7 Plus 1302 Charging Port Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Charging Port Replacement: adım 3, 2 resimden 1. HP 7 Plus 1302 Charging Port Replacement: adım 3, 2 resimden 2.
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Charging Port Replacement, Battery: adım 4, 2 resimden 1. HP 7 Plus 1302 Charging Port Replacement, Battery: adım 4, 2 resimden 2.
    • Push out the battery connector using the spudger.
    • Swing the battery connector clear of the connector socket.
  5. HP 7 Plus 1302 Charging Port Replacement: adım 5, 1 resimden 1.
    • Lift the battery from the device.
  6. HP 7 Plus 1302 Charging Port Replacement, Motherboard: adım 6, 2 resimden 1. HP 7 Plus 1302 Charging Port Replacement, Motherboard: adım 6, 2 resimden 2.
    • Pry the connector that attaches the front and back camera with a metal spudger.
  7. HP 7 Plus 1302 Charging Port Replacement: adım 7, 2 resimden 1. HP 7 Plus 1302 Charging Port Replacement: adım 7, 2 resimden 2.
    • Pull the camera from the connectors.
  8. HP 7 Plus 1302 Charging Port Replacement: adım 8, 2 resimden 1. HP 7 Plus 1302 Charging Port Replacement: adım 8, 2 resimden 2.
    • Identify the three T5x1mm screws and remove them with a Phillips #000
  9. HP 7 Plus 1302 Charging Port Replacement: adım 9, 2 resimden 1. HP 7 Plus 1302 Charging Port Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Unplug the connector with the tweezers.
    • Remove the tape.
  10. HP 7 Plus 1302 Charging Port Replacement: adım 10, 2 resimden 1. HP 7 Plus 1302 Charging Port Replacement: adım 10, 2 resimden 2.
    • Flip the ZIF connector with the metal spudger.
    • Pull the ribbon connector out.
  11. HP 7 Plus 1302 Charging Port Replacement: adım 11, 3 resimden 1. HP 7 Plus 1302 Charging Port Replacement: adım 11, 3 resimden 2. HP 7 Plus 1302 Charging Port Replacement: adım 11, 3 resimden 3.
    • Pull the orange tape with the tweezers.
    • Flip the ZIF connector with the spudger.
    • Pull the ribbon connector with the tweezers.
  12. HP 7 Plus 1302 Charging Port Replacement: adım 12, 1 resimden 1.
    • Remove the gray tape below the ribbon connector.
  13. HP 7 Plus 1302 Charging Port Replacement: adım 13, 2 resimden 1. HP 7 Plus 1302 Charging Port Replacement: adım 13, 2 resimden 2.
    • Flip the ZIF connector.
    • Pull the ribbon connector out with the tweezers.
  14. HP 7 Plus 1302 Charging Port Replacement: adım 14, 2 resimden 1. HP 7 Plus 1302 Charging Port Replacement: adım 14, 2 resimden 2.
    • Pull the circuit board off.
  15. HP 7 Plus 1302 Charging Port Replacement, Charging Port: adım 15, 1 resimden 1.
    • Desolder the four points on the charging port using the soldering iron.
    • Soldering iron will be hot be careful.
    • For more instructions about how to use the Soldering iron click here.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Damaris Torres-Crespo
204 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Baechle Spring 2017 IUPUI, Team 1-4, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S1G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 442
