Giriş
If the device is failing to charge it may be necessary to replace the charging port. The most difficult step will be soldering the charging port, it is important to make sure you have all tools required and follow the instructions precisely.
Neye ihtiyacın var
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Push out the battery connector using the spudger.
Swing the battery connector clear of the connector socket.
Pry the connector that attaches the front and back camera with a metal spudger.
Desolder the four points on the charging port using the soldering iron.
Bir başkası bu kılavuzu tamamladı.
