Ana içeriğe geç
HP Chromebook 11A G6 EE Touchpad Replacement
Neye ihtiyacın var
  1. HP Chromebook 11A G6 EE Touchpad Replacement, Keyboard: adım 1, 3 resimden 1. HP Chromebook 11A G6 EE Touchpad Replacement, Keyboard: adım 1, 3 resimden 2. HP Chromebook 11A G6 EE Touchpad Replacement, Keyboard: adım 1, 3 resimden 3.
    • Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
    • Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
    • Turn the computer over and open it as if you are going to use it.
  2. HP Chromebook 11A G6 EE Touchpad Replacement: adım 2, 3 resimden 1. HP Chromebook 11A G6 EE Touchpad Replacement: adım 2, 3 resimden 2. HP Chromebook 11A G6 EE Touchpad Replacement: adım 2, 3 resimden 3.
    • Use the iFixit opening tool to get between the keyboard bezel and the outer edge of the laptop.
    • There are several clips on all sides that will need to be released. You'll hear and feel a pop as each clip is released.
    • Move the opening tool or spudger around the perimeter until you unclipped the keyboard on all sides.
    • This will require a little force. The only thing you don't want to do is push the spudger too deep under the keyboard. You could damage the internals if you do.
  3. HP Chromebook 11A G6 EE Touchpad Replacement: adım 3, 2 resimden 1. HP Chromebook 11A G6 EE Touchpad Replacement: adım 3, 2 resimden 2.
    • Carefully lift the top of the keyboard up to access the ribbon cables connecting it to the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each connector. Then, pull the connector out.
    • Remove the keyboard and set aside.
  4. HP Chromebook 11A G6 EE Touchpad Replacement, Touchpad: adım 4, 3 resimden 1. HP Chromebook 11A G6 EE Touchpad Replacement, Touchpad: adım 4, 3 resimden 2. HP Chromebook 11A G6 EE Touchpad Replacement, Touchpad: adım 4, 3 resimden 3.
    • Peel back the tape that secures the battery cable connector to the system board.
    • Using the pointy end of the spudger, lift the tab lock up that holds the ribbon cable in place.
    • Slide the battery cable out from the connector.
  5. HP Chromebook 11A G6 EE Touchpad Replacement: adım 5, 3 resimden 1. HP Chromebook 11A G6 EE Touchpad Replacement: adım 5, 3 resimden 2. HP Chromebook 11A G6 EE Touchpad Replacement: adım 5, 3 resimden 3.
    • Remove the three 2.5 mm screws that secure the touchpad and touchpad bracket to the keyboard/top cover using a Phillips #1 screwdriver.
    • Remove the three 2.0 mm screws that secure the touchpad to the keyboard/top cover using a Phillips #1 screwdriver.
  6. HP Chromebook 11A G6 EE Touchpad Replacement: adım 6, 3 resimden 1. HP Chromebook 11A G6 EE Touchpad Replacement: adım 6, 3 resimden 2. HP Chromebook 11A G6 EE Touchpad Replacement: adım 6, 3 resimden 3.
    • Using a spudger, remove the touchpad bracket.
    • Push up on the touchpad from the keyboard side and remove the touchpad.
Sonuç
William S
575 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 113
