Ana içeriğe geç
HP Chromebook 11A G8 EE Speaker Replacement
Neye ihtiyacın var
  1. HP Chromebook 11A G8 EE Speaker Replacement, Keyboard Assembly: adım 1, 2 resimden 1. HP Chromebook 11A G8 EE Speaker Replacement, Keyboard Assembly: adım 1, 2 resimden 2.
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Speaker Replacement: adım 2, 3 resimden 1. HP Chromebook 11A G8 EE Speaker Replacement: adım 2, 3 resimden 2. HP Chromebook 11A G8 EE Speaker Replacement: adım 2, 3 resimden 3.
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Speaker Replacement: adım 3, 2 resimden 1. HP Chromebook 11A G8 EE Speaker Replacement: adım 3, 2 resimden 2.
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Speaker Replacement, Speaker: adım 4, 3 resimden 1. HP Chromebook 11A G8 EE Speaker Replacement, Speaker: adım 4, 3 resimden 2. HP Chromebook 11A G8 EE Speaker Replacement, Speaker: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the tweezers, carefully disconnect the battery cable from the motherboard.
    • Use the Phillips #0 screwdriver, remove the four 3.5 mm screws that secure the battery cover to the battery.
    • Using the tweezers, carefully remove the battery cover.
  5. HP Chromebook 11A G8 EE Speaker Replacement: adım 5, 3 resimden 1. HP Chromebook 11A G8 EE Speaker Replacement: adım 5, 3 resimden 2. HP Chromebook 11A G8 EE Speaker Replacement: adım 5, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the 3.5 mm screw that secures the speaker to the frame.
    • Peel back the clear sheet.
    • Using the tweezers, carefully disconnect the speaker cable from the motherboard.
  6. HP Chromebook 11A G8 EE Speaker Replacement: adım 6, 2 resimden 1. HP Chromebook 11A G8 EE Speaker Replacement: adım 6, 2 resimden 2.
    • Remove the speaker cable from the routing channel on the keyboard.
    • Using your hands, carefully lift the speakers out of the alignment pins, and remove.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ella Portwood
684 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 12
Her zaman: 310
