Ana içeriğe geç
HP Chromebook 14-ak041dx RAM Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-ak041dx RAM Replacement, Keyboard: adım 1, 2 resimden 1. HP Chromebook 14-ak041dx RAM Replacement, Keyboard: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • You will need a pair of tweezers and a Phillips screwdriver.
    • Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
  2. HP Chromebook 14-ak041dx RAM Replacement: adım 2, 3 resimden 1. HP Chromebook 14-ak041dx RAM Replacement: adım 2, 3 resimden 2. HP Chromebook 14-ak041dx RAM Replacement: adım 2, 3 resimden 3.
    • Using a pair of tweezers, remove the five grey silicone covers.
    • Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
    • Place them aside where they will not be lost.
  3. HP Chromebook 14-ak041dx RAM Replacement: adım 3, 3 resimden 1. HP Chromebook 14-ak041dx RAM Replacement: adım 3, 3 resimden 2. HP Chromebook 14-ak041dx RAM Replacement: adım 3, 3 resimden 3.
    • Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
    • Place the keyboard aside. Inspect for any visual damage or marks.
  4. HP Chromebook 14-ak041dx RAM Replacement, Battery: adım 4, 2 resimden 1. HP Chromebook 14-ak041dx RAM Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the four 3mm Phillips #000 screws holding the battery in place.
  5. HP Chromebook 14-ak041dx RAM Replacement: adım 5, 3 resimden 1. HP Chromebook 14-ak041dx RAM Replacement: adım 5, 3 resimden 2. HP Chromebook 14-ak041dx RAM Replacement: adım 5, 3 resimden 3.
    Satın Al
    • Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
    • Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
  6. HP Chromebook 14-ak041dx RAM Replacement: adım 6, 1 resimden 1.
    • Carefully lift the battery out of the laptop.
  7. HP Chromebook 14-ak041dx RAM Replacement, Heat Sink: adım 7, 3 resimden 1. HP Chromebook 14-ak041dx RAM Replacement, Heat Sink: adım 7, 3 resimden 2. HP Chromebook 14-ak041dx RAM Replacement, Heat Sink: adım 7, 3 resimden 3.
    • Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
    • Remove the heat sink from the laptop.
  8. HP Chromebook 14-ak041dx RAM Replacement, Wireless Card: adım 8, 2 resimden 1. HP Chromebook 14-ak041dx RAM Replacement, Wireless Card: adım 8, 2 resimden 2.
    • Remove the single 2.5mm Phillips #00 screw from the wireless card.
    • Gently pull the wireless card from the motherboard to remove it.
  9. HP Chromebook 14-ak041dx RAM Replacement, Motherboard: adım 9, 3 resimden 1. HP Chromebook 14-ak041dx RAM Replacement, Motherboard: adım 9, 3 resimden 2. HP Chromebook 14-ak041dx RAM Replacement, Motherboard: adım 9, 3 resimden 3.
    Satın Al
    • Gently pull the wire connector with a pair of tweezers to free it from the motherboard.
    • Use a pair of tweezers to remove the black ribbon cable from its connector.
    • Use the tweezers to detach the wire connector from the bottom left corner of the motherboard.
  10. HP Chromebook 14-ak041dx RAM Replacement: adım 10, 3 resimden 1. HP Chromebook 14-ak041dx RAM Replacement: adım 10, 3 resimden 2. HP Chromebook 14-ak041dx RAM Replacement: adım 10, 3 resimden 3.
    • Remove the four Phillips #000 screws holding the motherboard in place.
    • Remove the motherboard from the laptop.
  11. HP Chromebook 14-ak041dx RAM Replacement, RAM: adım 11, 1 resimden 1.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 849
