Ana içeriğe geç
HP Chromebook 14-q029wm Screen Replacement
Neye ihtiyacın var
  1. HP Chromebook 14-q029wm Screen  Replacement, Screen: adım 1, 3 resimden 1. HP Chromebook 14-q029wm Screen  Replacement, Screen: adım 1, 3 resimden 2. HP Chromebook 14-q029wm Screen  Replacement, Screen: adım 1, 3 resimden 3.
    • Remove these two sticker covers which cover two screws.
    • Remove the two 2mm Phillips #0 screws.
  2. HP Chromebook 14-q029wm Screen  Replacement: adım 2, 3 resimden 1. HP Chromebook 14-q029wm Screen  Replacement: adım 2, 3 resimden 2. HP Chromebook 14-q029wm Screen  Replacement: adım 2, 3 resimden 3.
    • Unsnap the plastic edge around the screen using an opening tool.
    • You will have to close the screen partially to unsnap the plastic near the hinge.
    • Be careful not to break the plastic.
  3. HP Chromebook 14-q029wm Screen  Replacement: adım 3, 1 resimden 1.
    • Remove the four 3mm Phillips #0 screws.
    • Be careful not to drop the screen after you remove the last screw.
  4. HP Chromebook 14-q029wm Screen  Replacement: adım 4, 3 resimden 1. HP Chromebook 14-q029wm Screen  Replacement: adım 4, 3 resimden 2. HP Chromebook 14-q029wm Screen  Replacement: adım 4, 3 resimden 3.
    • Unplug the wire attached at the bottom of the screen.
    • To unplug the wire, peel back the sticker and gently pull the sticker holding close to the wire to unplug.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Pratt
669 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G5, Barthe Fall 2019 UMass Dartmouth, Team S1-G5, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S1G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 441
