Giriş
If the keyboard on the HP Chromebook 14-q063cl is not responding when you press the keys, it needs to be replaced. Use this guide to remove and replace the keyboard.
The keyboard is one of the main components through which you give your laptop commands. If one or more of the keys are not responding, the whole keyboard needs to be removed in order to properly address the issue.
For more information on troubleshooting issues for the keyboard assembly, take a look at the Troubleshooting page for assistance.
Before beginning this guide, power down the device and disconnect it from the charger
Neye ihtiyacın var
Flip the laptop upside down so that the bottom is facing upwards.
Use Phillips #0 screwdriver to remove nine 6.7 mm screws from the bottom panel.
