Ana içeriğe geç
HP Compaq NC6120 Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Compaq NC6120 Cooling Fan Replacement, Cooling Fan: adım 1, 3 resimden 1. HP Compaq NC6120 Cooling Fan Replacement, Cooling Fan: adım 1, 3 resimden 2. HP Compaq NC6120 Cooling Fan Replacement, Cooling Fan: adım 1, 3 resimden 3.
    • Use the point of a spudger to push on alternating sides of the fan connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
    • Place the cable off to the side so that it is out of the way.
    FixBot'a Sor
  2. HP Compaq NC6120 Cooling Fan Replacement: adım 2, 2 resimden 1. HP Compaq NC6120 Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 7.0 mm screws on the top left and top right corners of the cooling fan.
    FixBot'a Sor
  3. HP Compaq NC6120 Cooling Fan Replacement: adım 3, 2 resimden 1. HP Compaq NC6120 Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Remove the fan from the laptop.
    FixBot'a Sor
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Mateo Cuellar
601 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-4, Forte Spring 2015 Cal Poly, Team 17-4, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 38
Her zaman: 898
