Ana içeriğe geç
HP Compaq Presario CQ56-110US RAM Replacement
Jorge Villarreal
Jorge Villarreal ve 3 diğer katkıda bulunanlar
En son May 25, 2017 tarihinde güncellendi
5 - 7 dakika
Kolay
Use this guide to replace the RAM stick. If your computer freezes up momentarily while running several programs, this may be the guide for you.
Neye ihtiyacın var
Aletler
  1. HP Compaq Presario CQ56-110US RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Ensure the laptop is unplugged and completely powered off. Loosen the three small screws using a #1 Phillips screwdriver.
    • The screws do not come free from the panel. They only need to be loosened enough so the panel can be lifted/pried.
  2. HP Compaq Presario CQ56-110US RAM Replacement: adım 2, 1 resimden 1.
    • Carefully pry the panel up using a plastic opening tool.
    • Pull the panel away from the laptop and set it off to the side.
  3. HP Compaq Presario CQ56-110US RAM Replacement: adım 3, 2 resimden 1. HP Compaq Presario CQ56-110US RAM Replacement: adım 3, 2 resimden 2.
    • Locate the latches on the RAM
    • Push the latches away from the RAM
  4. HP Compaq Presario CQ56-110US RAM Replacement: adım 4, 1 resimden 1.
    • Carefully pry the RAM upwards
    • Remove the RAM
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jorge Villarreal
150 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 8-4, Eyestone Spring 2017 USF Tampa, Team 8-4, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S8G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 20
Son 30 gün: 23
Her zaman: 1,006
