Ana içeriğe geç
HP Compaq Presario V3000 Battery Replacement
Ricky Jaimez
Ricky Jaimez ve 6 diğer katkıda bulunanlar
En son May 11, 2017 tarihinde güncellendi
5 dakika
Kolay
Battery replacement is a relatively easy task that requires no tools. Just be sure that you have removed the power plug and allowed the laptop time to cool down.
  1. HP Compaq Presario V3000 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
    • The battery may be warm or even HOT to the touch.
    • Locate the battery EJECT latch.
  2. HP Compaq Presario V3000 Battery Replacement: adım 2, 2 resimden 1. HP Compaq Presario V3000 Battery Replacement: adım 2, 2 resimden 2.
    • Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
    • The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
    • When replacing the battery, you DO NOT need to adjust the latch. Once the battery is replaced, snap it into place and the latch will return to normal.
  3. HP Compaq Presario V3000 Battery Replacement: adım 3, 2 resimden 1. HP Compaq Presario V3000 Battery Replacement: adım 3, 2 resimden 2.
    • Pull the battery up and towards you to remove it from the laptop chassis.
    • Once the battery is out, you will be able to check the battery label for the replacement part number.
    • The part number is needed when purchasing a new battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ricky Jaimez
369 İtibar
2 adet Kılavuz yazıldı
Ekip
Bir Yorum
I need the battery remove switch
Aadhi Dev - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 16
Her zaman: 2,552
