Ana içeriğe geç
HP EliteBook 1040 G4 Coin Cell Battery  Replacement
SW Reeves
SW Reeves ve 2 diğer katkıda bulunanlar
En son December 15, 2023 tarihinde güncellendi
10 - 20 dakika
Orta
Use this guide to replace the coin cell battery on the HP Elitebook 1040 G4. The coin cell battery is essential in laptops to retain certain system settings, such as date and time, while the device is powered off. If you are experiencing problems regarding the time settings or other internal system settings, you may need to replace the coin cell battery.
To complete this guide, you will need a T5 Torx head screwdriver and a Phillips #1 and #00 screwdriver.
Before beginning, be sure to completely power off and unplug your computer.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Back Cover: adım 1, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: adım 2, 2 resimden 1. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: adım 2, 2 resimden 2.
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Battery: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: adım 4, 2 resimden 1. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: adım 4, 2 resimden 2.
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: adım 5, 2 resimden 1. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: adım 5, 2 resimden 2.
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Coin Cell Battery: adım 6, 1 resimden 1.
    • Carefully disconnect the pin connector from the right side of the speaker assembly.
  7. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: adım 7, 2 resimden 1. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: adım 7, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 6 mm black screws securing the speakers to the device.
    • Lift the speakers up and out.
  8. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: adım 8, 1 resimden 1.
    • Carefully disconnect the coin cell battery cable located under the motherboard.
  9. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: adım 9, 1 resimden 1.
    • Remove the coin cell battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 702
