Ana içeriğe geç
HP EliteBook 745 G2 WiFi Chip Replacement
Neye ihtiyacın var
  1. HP EliteBook 745 G2 WiFi Chip Replacement, Battery: adım 1, 1 resimden 1.
    • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
  2. HP EliteBook 745 G2 WiFi Chip Replacement: adım 2, 2 resimden 1. HP EliteBook 745 G2 WiFi Chip Replacement: adım 2, 2 resimden 2.
    • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
  3. HP EliteBook 745 G2 WiFi Chip Replacement: adım 3, 2 resimden 1. HP EliteBook 745 G2 WiFi Chip Replacement: adım 3, 2 resimden 2.
    • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
  4. HP EliteBook 745 G2 WiFi Chip Replacement, WiFi Chip: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
  5. HP EliteBook 745 G2 WiFi Chip Replacement: adım 5, 1 resimden 1.
    • Using precision tweezers grab the coaxial cable leads and disconnect them using steady gentle force.
  6. HP EliteBook 745 G2 WiFi Chip Replacement: adım 6, 1 resimden 1.
    • Using the Phillips #0, remove the 1.5 mm screw holding the wifi card in place. Once the screws are removed, gently lift the card away from laptop.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 40
Her zaman: 631
