Ana içeriğe geç
HP EliteBook 820 G3 Battery Replacement
Neye ihtiyacın var
  1. HP EliteBook 820 G3 Battery Replacement, Back Cover: adım 1, 2 resimden 1. HP EliteBook 820 G3 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
    • Keep track of where the screw covers were attached to as there are four different sizes.
  2. HP EliteBook 820 G3 Battery Replacement: adım 2, 2 resimden 1. HP EliteBook 820 G3 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
    • Lift off the back cover with your hands.
  3. HP EliteBook 820 G3 Battery Replacement, Battery: adım 3, 3 resimden 1. HP EliteBook 820 G3 Battery Replacement, Battery: adım 3, 3 resimden 2. HP EliteBook 820 G3 Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Loosen the single captive screw holding the battery in place using a Phillips #00 screwdriver.
    • Lift the black tab upwards and lift the battery out of its slot.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sarah Bisimwa
247 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Class Fall 2022 Gateway, Team 1-1, Class Fall 2022 üyesi
GCC-CLASS-F22S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 82
Her zaman: 1,298
