Ana içeriğe geç
HP EliteBook 840 G7 Battery Replacement
Neye ihtiyacın var
  1. HP EliteBook 840 G7 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Battery Replacement: adım 2, 1 resimden 1.
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Battery Replacement: adım 4, 3 resimden 1. HP EliteBook 840 G7 Battery Replacement: adım 4, 3 resimden 2. HP EliteBook 840 G7 Battery Replacement: adım 4, 3 resimden 3.
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Battery Replacement: adım 5, 3 resimden 1. HP EliteBook 840 G7 Battery Replacement: adım 5, 3 resimden 2. HP EliteBook 840 G7 Battery Replacement: adım 5, 3 resimden 3.
    • Lift up the battery with you hands or tools.
Sonuç
Pedro Ramos Espinoza
790 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Pee Spring 2022 Gateway, Team 1-1, Pee Spring 2022 üyesi
GCC-PEE-S22S1G1
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 22
Son 30 gün: 108
Her zaman: 2,535
