Giriş
Use this guide to replace or upgrade the memory modules (aka RAM) in your HP EliteBook 840 G9 laptop.
This laptop has two slots that support DDR5 SO‑DIMM memory modules.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
Neye ihtiyacın var
Use a Phillips screwdriver to fully loosen (not remove) the five captive screws securing the bottom cover.
Position your laptop so the rear edge (with the screen hinge) is closest to you.
Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
Use your spudger to pry up the cover to release the clip securing it.
Leave the spudger inserted under the bottom cover for the next step.
Slide the cover towards the screen hinge to disengage the clips on the opposite edge.
Lift and remove the cover.
Position your laptop so the front edge (opposite the screen hinges) is closest to you.
Use the point of a spudger to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
Use tweezers or your fingers to peel the tape off the bottom edge of the heat sink.
Bu adımda kullanılan alet:iFixit Opening Tool$1.99
Use an opening tool to pry up the edges of the memory module's metal shield.
Simultaneously push out the metal arms on each side of the memory module until they disengage and the module pops up at a slight angle.
Pull the module out of its socket to remove it.
Use the same process to remove the other memory module.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Bir başkası bu kılavuzu tamamladı.
