Giriş
Use this guide to replace or upgrade the SSD storage in your HP EliteBook 840 G9 laptop.
This laptop has one slot that supports an M.2 2280 PCIe SSD, up to 2 TB.
Before starting this repair, consider backing up your current drive. If necessary, familiarize yourself with a disk cloning utility so you’ll be ready to transfer your data to the new drive.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
Neye ihtiyacın var
Use a Phillips screwdriver to fully loosen (not remove) the five captive screws securing the bottom cover.
Position your laptop so the rear edge (with the screen hinge) is closest to you.
Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
Use your spudger to pry up the cover to release the clip securing it.
Leave the spudger inserted under the bottom cover for the next step.
Slide the cover towards the screen hinge to disengage the clips on the opposite edge.
Lift and remove the cover.
Position your laptop so the front edge (opposite the screen hinges) is closest to you.
Use the point of a spudger to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
Use the point of a spudger to peel up the tape enough that you can grip it with a pair of tweezers or your fingers.
Peel the tape off of the shield.
Use an opening tool to pry up the edges of the SSD's metal shield.
Use the pull tab on the top edge to lift and remove the shield.
Use a Phillips screwdriver to remove the 2.5 mm‑long screw securing the SSD.
Grip the SSD by its edges and pull it straight out of its socket to remove it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
