HP EliteBook 8440p Keyboard Replacement
Giriş
1. adıma gitAre keys on your HP EliteBook 8440p laptop keyboard broken, stuck, or dirty? It might be time to replace your keyboard, and this guide will teach you how to do it yourself! Removing the keyboard is also a crucial step to getting inside the computer to make repairs or clean.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
Turn the laptop over and open the cover.
Push down the little clips located between the Function Keys to release the top of the keyboard. Lift the keyboard gently with a forward and upward motion.
Rest the keyboard over the touch pad.
The tabs at the top of the keyboard need to be slid towards the center to release it.
23 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
The top of the keyboard has locking tabs that need to be pulled back towards the keyboard center or it won't come out. They hold the replacement keyboard in place long enough to get the screws into it.
But you don’t need to remove the battery.
Perfect guide except for keyboard tabs mentioned in comment from Robert Taylor! Well done!
PERFECT! It took me 15 minutes to replace the keyboard!
