Ana içeriğe geç
HP EliteBook 8470p Hard Drive Replacement
Neye ihtiyacın var
  1. HP EliteBook 8470p Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
    • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
  2. HP EliteBook 8470p Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the battery latch positioned to the right over to the right side. Hold it there.
  3. HP EliteBook 8470p Hard Drive Replacement: adım 3, 1 resimden 1.
    • With the latch opened, pull the battery out of its socket firmly.
    • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
  4. HP EliteBook 8470p Hard Drive Replacement, Case/Service Cover: adım 4, 1 resimden 1.
    • With the laptop latch still facing away from you, slide the left release latch to the left.
    • Some models may have a screw installed on this latch, if so, be sure to remove it first to avoid damaging the latch.
  5. HP EliteBook 8470p Hard Drive Replacement: adım 5, 2 resimden 1. HP EliteBook 8470p Hard Drive Replacement: adım 5, 2 resimden 2.
    • Slide the door away from you, toward the opening latch.
    • Lift the door upwards away from the computer.
  6. HP EliteBook 8470p Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 1. HP EliteBook 8470p Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Pull tab to the right and lift up to open case.
  7. HP EliteBook 8470p Hard Drive Replacement: adım 7, 2 resimden 1. HP EliteBook 8470p Hard Drive Replacement: adım 7, 2 resimden 2.
    • Loosen the three captive screws securing the hard drive to the motherboard with a Phillips #00 screwdriver.
  8. HP EliteBook 8470p Hard Drive Replacement: adım 8, 1 resimden 1.
    • Pull the tab on the hard drive towards the near side of the case.
    • Be sure the hard drive unplugs from the motherboard in this step.
  9. HP EliteBook 8470p Hard Drive Replacement: adım 9, 1 resimden 1.
    • Pull up and remove the hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Owen Bangs
656 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G3
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 77
Her zaman: 1,780
