Ana içeriğe geç
HP EliteBook 8470p Hard Drive Replacement
Neye ihtiyacın var
  1. HP EliteBook 8470p Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
    • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
  2. HP EliteBook 8470p Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the battery latch positioned to the right over to the right side. Hold it there.
  3. HP EliteBook 8470p Hard Drive Replacement: adım 3, 1 resimden 1.
    • With the latch opened, pull the battery out of its socket firmly.
    • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
  4. HP EliteBook 8470p Hard Drive Replacement, Case/Service Cover: adım 4, 1 resimden 1.
    • With the laptop latch still facing away from you, slide the left release latch to the left.
    • Some models may have a screw installed on this latch, if so, be sure to remove it first to avoid damaging the latch.
  5. HP EliteBook 8470p Hard Drive Replacement: adım 5, 2 resimden 1. HP EliteBook 8470p Hard Drive Replacement: adım 5, 2 resimden 2.
    • Slide the door away from you, toward the opening latch.
    • Lift the door upwards away from the computer.
  6. HP EliteBook 8470p Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 1. HP EliteBook 8470p Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Pull tab to the right and lift up to open case.
  7. HP EliteBook 8470p Hard Drive Replacement: adım 7, 2 resimden 1. HP EliteBook 8470p Hard Drive Replacement: adım 7, 2 resimden 2.
    • Loosen the three captive screws securing the hard drive to the motherboard with a Phillips #00 screwdriver.
  8. HP EliteBook 8470p Hard Drive Replacement: adım 8, 1 resimden 1.
    • Pull the tab on the hard drive towards the near side of the case.
    • Be sure the hard drive unplugs from the motherboard in this step.
  9. HP EliteBook 8470p Hard Drive Replacement: adım 9, 1 resimden 1.
    • Pull up and remove the hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Owen Bangs
660 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G3
5 Üyeler
7 adet Kılavuz yazıldı
3 Yorum
I did all that but then both my Windows 10 recovery drive and an apparently successful Unbuntu 24.04 installation failed to boot. Tried the diagnostics without issue. Some time into the Windows install it reports an error then barfs. The Windows diagnostics failed to locate any issue. Not helpful.
Guessing, given the usual multiple reboots on installing Windows the new hard drive will not allow itself to reboot. Currently I am bit stuffed.
Thanks for the useful detail above.
SteveW - Yanıt
I am here because a) my current Windows10 is in some way toxic and will no longer update itself, b) my hard drive is nearly full, c) I now use Ubuntu in preference to Win10.
Update: I have resorted to cloning the original drive to a new WD 1Tb SSD using a utility I found on the Western Digital site. I used the Windows10 recovery USB I made earlier. Top Tip: Always have a Windows 10/11 Recovery Drive.
The newly cloned drive booted the cloned toxic Win10. I then plugged in my Recovery Drive and restarted. The thing barfed as before. I am guessing that there is some secured book lock that is perhaps tied to the old drive and any attempt to recover Windows fails.
Currently I have a non-booting HP Elitebook 8470p. I am hacked off with Windows10. Its far too slow for the first hour from boot because, and on two systems, its thrashing the hard drive for an hour. As this new drive is now stuffed will re-clone and install Unbuntu 24.04. I suspect the magic feature will prevent this.
SteveW - Yanıt
And finally ... Having had some success using the clone of the original drive followed by three failures to re-install Windows10 over the top (remember the original Win10 was refusing to update any more) from created Rescue USBs and a successful install of Ubuntu24.04 followed then by a total failure to find any bootable image on restart I found this site:
https://askubuntu.com/questions/1323124/...
Repeated as a link here : Link to Ask Ubuntu
This suggested configuring the BIOS boot mechanism from "UEFI with CSM" to "UEFI Without CSM" and now, after yet another Ubuntu install it boots. The link also outlines difficulties getting Windows to ever work on a replaced hard drive. Totally given up on getting Window10 going. Its now deprecated and I really couldn't cope with Windows 11. Phew.
Hope the above narrative is of some help to others.
One point being the WD sourced clone s/w identified the original drive as protected, I unprotected it.
SteveW - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 28
Son 30 gün: 79
Her zaman: 2,373
