Ana içeriğe geç
HP EliteBook 8560w CD/DVD ROM Replacement
Neye ihtiyacın var
  1. HP EliteBook 8560w CD/DVD ROM Replacement, Battery: adım 1, 2 resimden 1. HP EliteBook 8560w CD/DVD ROM Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w CD/DVD ROM Replacement: adım 2, 1 resimden 1.
    • Pull the battery out.
  3. HP EliteBook 8560w CD/DVD ROM Replacement, Back Panel: adım 3, 2 resimden 1. HP EliteBook 8560w CD/DVD ROM Replacement, Back Panel: adım 3, 2 resimden 2.
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w CD/DVD ROM Replacement: adım 4, 1 resimden 1.
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w CD/DVD ROM Replacement, CD/DVD ROM: adım 5, 2 resimden 1. HP EliteBook 8560w CD/DVD ROM Replacement, CD/DVD ROM: adım 5, 2 resimden 2.
    • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
    • The screw does not have to come out completely.
  6. HP EliteBook 8560w CD/DVD ROM Replacement: adım 6, 3 resimden 1. HP EliteBook 8560w CD/DVD ROM Replacement: adım 6, 3 resimden 2. HP EliteBook 8560w CD/DVD ROM Replacement: adım 6, 3 resimden 3.
    • Push the metal tip to the left with a screwdriver.
  7. HP EliteBook 8560w CD/DVD ROM Replacement: adım 7, 2 resimden 1. HP EliteBook 8560w CD/DVD ROM Replacement: adım 7, 2 resimden 2.
    • Pull out the CD/DVD ROM with your hand.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 684
