Ana içeriğe geç
HP EliteBook 8560w Hard Drive Replacement
Neye ihtiyacın var
  1. HP EliteBook 8560w Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP EliteBook 8560w Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Hard Drive Replacement: adım 2, 1 resimden 1.
    • Pull the battery out.
  3. HP EliteBook 8560w Hard Drive Replacement, Back Panel: adım 3, 2 resimden 1. HP EliteBook 8560w Hard Drive Replacement, Back Panel: adım 3, 2 resimden 2.
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Hard Drive Replacement: adım 4, 1 resimden 1.
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 1. HP EliteBook 8560w Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 2.
    • Make sure your device is powered off and its battery removed.
    • Remove the four M2.5x8mm screws with Phillips #0 screwdriver and lift up the panel to access your Hard Drive.
  6. HP EliteBook 8560w Hard Drive Replacement: adım 6, 3 resimden 1. HP EliteBook 8560w Hard Drive Replacement: adım 6, 3 resimden 2. HP EliteBook 8560w Hard Drive Replacement: adım 6, 3 resimden 3.
    • Remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Slide the hard drive to the left and lift it to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,681
