Ana içeriğe geç
HP EliteBook 8560w Keyboard Replacement
Neye ihtiyacın var
  1. HP EliteBook 8560w Keyboard Replacement, Battery: adım 1, 2 resimden 1. HP EliteBook 8560w Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Keyboard Replacement: adım 2, 1 resimden 1.
    • Pull the battery out.
  3. HP EliteBook 8560w Keyboard Replacement, Back Panel: adım 3, 2 resimden 1. HP EliteBook 8560w Keyboard Replacement, Back Panel: adım 3, 2 resimden 2.
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Keyboard Replacement: adım 4, 1 resimden 1.
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: adım 5, 2 resimden 1. HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: adım 5, 2 resimden 2.
    • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
    • The screw does not have to come out completely.
  6. HP EliteBook 8560w Keyboard Replacement: adım 6, 3 resimden 1. HP EliteBook 8560w Keyboard Replacement: adım 6, 3 resimden 2. HP EliteBook 8560w Keyboard Replacement: adım 6, 3 resimden 3.
    • Push the metal tip to the left with a screwdriver.
  7. HP EliteBook 8560w Keyboard Replacement: adım 7, 2 resimden 1. HP EliteBook 8560w Keyboard Replacement: adım 7, 2 resimden 2.
    • Pull out the CD/DVD ROM with your hand.
  8. HP EliteBook 8560w Keyboard Replacement, Keyboard: adım 8, 1 resimden 1.
    • Unscrew three M2.5x8mm screws using Phillips #0 screwdriver.
  9. HP EliteBook 8560w Keyboard Replacement: adım 9, 3 resimden 1. HP EliteBook 8560w Keyboard Replacement: adım 9, 3 resimden 2. HP EliteBook 8560w Keyboard Replacement: adım 9, 3 resimden 3.
    • Put your finger through the hole to push out the keyboard from its place.
    • Keep in mind to push rather hard to fully remove the keyboard from the actual laptop.
  10. HP EliteBook 8560w Keyboard Replacement: adım 10, 3 resimden 1. HP EliteBook 8560w Keyboard Replacement: adım 10, 3 resimden 2. HP EliteBook 8560w Keyboard Replacement: adım 10, 3 resimden 3.
    • Carefully lift keyboard to reveal connection strips.
    • Unlock the latch holding the connection strips.
    • Pull out the connection strips from the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 23
Son 30 gün: 40
Her zaman: 1,602
