Ana içeriğe geç
HP EliteBook 8560w Memory Replacement
Neye ihtiyacın var
  1. HP EliteBook 8560w Memory Replacement, Battery: adım 1, 2 resimden 1. HP EliteBook 8560w Memory Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Memory Replacement: adım 2, 1 resimden 1.
    • Pull the battery out.
  3. HP EliteBook 8560w Memory Replacement, Back Panel: adım 3, 2 resimden 1. HP EliteBook 8560w Memory Replacement, Back Panel: adım 3, 2 resimden 2.
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Memory Replacement: adım 4, 1 resimden 1.
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Memory Replacement, CD/DVD ROM: adım 5, 2 resimden 1. HP EliteBook 8560w Memory Replacement, CD/DVD ROM: adım 5, 2 resimden 2.
    • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
    • The screw does not have to come out completely.
  6. HP EliteBook 8560w Memory Replacement: adım 6, 3 resimden 1. HP EliteBook 8560w Memory Replacement: adım 6, 3 resimden 2. HP EliteBook 8560w Memory Replacement: adım 6, 3 resimden 3.
    • Push the metal tip to the left with a screwdriver.
  7. HP EliteBook 8560w Memory Replacement: adım 7, 2 resimden 1. HP EliteBook 8560w Memory Replacement: adım 7, 2 resimden 2.
    • Pull out the CD/DVD ROM with your hand.
  8. HP EliteBook 8560w Memory Replacement, Keyboard: adım 8, 1 resimden 1.
    • Unscrew three M2.5x8mm screws using Phillips #0 screwdriver.
  9. HP EliteBook 8560w Memory Replacement: adım 9, 3 resimden 1. HP EliteBook 8560w Memory Replacement: adım 9, 3 resimden 2. HP EliteBook 8560w Memory Replacement: adım 9, 3 resimden 3.
    • Put your finger through the hole to push out the keyboard from its place.
    • Keep in mind to push rather hard to fully remove the keyboard from the actual laptop.
  10. HP EliteBook 8560w Memory Replacement: adım 10, 3 resimden 1. HP EliteBook 8560w Memory Replacement: adım 10, 3 resimden 2. HP EliteBook 8560w Memory Replacement: adım 10, 3 resimden 3.
    • Carefully lift keyboard to reveal connection strips.
    • Unlock the latch holding the connection strips.
    • Pull out the connection strips from the motherboard.
  11. HP EliteBook 8560w Memory Replacement, Memory: adım 11, 3 resimden 1. HP EliteBook 8560w Memory Replacement, Memory: adım 11, 3 resimden 2. HP EliteBook 8560w Memory Replacement, Memory: adım 11, 3 resimden 3.
    • Your HP EliteBook 8560w has two pairs of RAM: one below the keyboard and the other below the back panel. This guide begins removing the pair below the keyboard, then proceeds to the one below the back panel.
    • Pull both metal parts away from memory pair. Lift memory pair and it will come out.
  12. HP EliteBook 8560w Memory Replacement: adım 12, 3 resimden 1. HP EliteBook 8560w Memory Replacement: adım 12, 3 resimden 2. HP EliteBook 8560w Memory Replacement: adım 12, 3 resimden 3.
    • Flip device upside down. Pull metal bars away from the memory. Lift the memory up and it will pop out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
The best explanation to a memory replace ever! Congratulations!
Please! Do the same to a graphic card replace for HP 8560W!! Please..PLease...
And, I have a question: MAY I INSTALL AN MSATA HARD DISK ON WWAN SLOT from this machine HP 8560W Elitebook workstation??? May I?
l g - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 42
Her zaman: 2,096
