Ana içeriğe geç
HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement
Joshua Bruno
Joshua Bruno ve 2 diğer katkıda bulunanlar
En son May 27, 2024 tarihinde güncellendi
20 - 30 dakika
Orta
This guide provides instructions on how to remove and replace the thumb scanner for the HP EliteBook x360 1030 G3.
The thumb scanner allows you to lock and unlock your computer using your thumb print. A failing thumb scanner simply does not read your thumb print, which may pose a problem in unlocking or locking your computer.
Before removing the thumb scanner, check to see if there happens to be any debris or contaminants on it. Cleaning the thumb scanner can be a simple solution to fixing the component. If cleaning it does not work, make sure to power off the laptop before attempting to replace.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 2, 1 resimden 1.
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 4, 2 resimden 1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 4, 2 resimden 2.
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 5, 1 resimden 1.
    • Gently lift the battery out of its place.
  6. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Touchpad: adım 6, 2 resimden 1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Touchpad: adım 6, 2 resimden 2.
    • Remove the six 1.95 mm JIS #000 screws that secure the metal frame of the touchpad.
  7. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 7, 3 resimden 1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 7, 3 resimden 2. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 7, 3 resimden 3.
    • Lift the small white ZIF connector from the front using a spudger tool or your finger.
    • Only lift the white hinge securing the Flexed Flat Cable making sure the unit stays secure to the board.
  8. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 8, 1 resimden 1.
    • Pull the yellow and orange striped ribbon away.
  9. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 9, 1 resimden 1.
    • Lift the touchpad up from the computer board by the metal frame.
  10. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Speakers: adım 10, 3 resimden 1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Speakers: adım 10, 3 resimden 2. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Speakers: adım 10, 3 resimden 3.
    • Remove the two 3.52 mm JIS #000 screws from the left speaker.
    • The speakers are magnetic, so carefully remove from its magnetic place.
  11. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 11, 3 resimden 1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 11, 3 resimden 2. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 11, 3 resimden 3.
    • Follow the red and black wire and you will see the two wire brackets.
    • Use the spudger to slide it and push the wire out of the brackets, then take it out.
  12. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 12, 3 resimden 1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 12, 3 resimden 2. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 12, 3 resimden 3.
    • Remove the two 3.52 mm JIS #000 screws from the right speaker and carefully remove from its magnetic place.
    • Remove the black tape with your hand that is around wire.
  13. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 13, 3 resimden 1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 13, 3 resimden 2. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 13, 3 resimden 3.
    • Remove the black tape from the mother board with your hand.
    • Unplug the green and white wire plug gently, and the red and black wire plug gently with your hand.
  14. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Thumbprint Scanner: adım 14, 2 resimden 1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Thumbprint Scanner: adım 14, 2 resimden 2.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
    • Use the Halberd Spudger to lift the ZIF connector tab and free the thumbprint ribbon cable.
    • Be sure not to remove the plastic hinge from the board. It only flips up to release the tape wire.
  15. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 15, 1 resimden 1.
    • Remove the two 2.39 mm JIS #000 screws in a counter-clockwise motion.
  16. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 16, 3 resimden 1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 16, 3 resimden 2. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 16, 3 resimden 3.
    • Lift the metal cover, and then pull it out of its plastic bracket towards the motherboard.
  17. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 17, 2 resimden 1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: adım 17, 2 resimden 2.
    • Lift the whole component from the board.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 369
