Ana içeriğe geç
HP EliteBook x360 830 G6 Back Cover Replacement
Neye ihtiyacın var
  1. HP EliteBook x360 830 G6 Back Cover Replacement, Unfasten the back cover: adım 1, 1 resimden 1.
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Back Cover Replacement, Release the clips: adım 2, 2 resimden 1. HP EliteBook x360 830 G6 Back Cover Replacement, Release the clips: adım 2, 2 resimden 2.
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Back Cover Replacement, Release the remaining clips: adım 3, 2 resimden 1. HP EliteBook x360 830 G6 Back Cover Replacement, Release the remaining clips: adım 3, 2 resimden 2.
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Back Cover Replacement, Remove the back cover: adım 4, 3 resimden 1. HP EliteBook x360 830 G6 Back Cover Replacement, Remove the back cover: adım 4, 3 resimden 2. HP EliteBook x360 830 G6 Back Cover Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Clay Eickemeyer
69.499 İtibar
453 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
141 Üyeler
17.895 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 68
Her zaman: 808
