Ana içeriğe geç
HP EliteBook x360 830 G6 RAM Replacement
Neye ihtiyacın var
  1. HP EliteBook x360 830 G6 RAM Replacement, Unfasten the back cover: adım 1, 1 resimden 1.
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 RAM Replacement, Release the clips: adım 2, 2 resimden 1. HP EliteBook x360 830 G6 RAM Replacement, Release the clips: adım 2, 2 resimden 2.
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 RAM Replacement, Release the remaining clips: adım 3, 2 resimden 1. HP EliteBook x360 830 G6 RAM Replacement, Release the remaining clips: adım 3, 2 resimden 2.
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 RAM Replacement, Remove the back cover: adım 4, 3 resimden 1. HP EliteBook x360 830 G6 RAM Replacement, Remove the back cover: adım 4, 3 resimden 2. HP EliteBook x360 830 G6 RAM Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 RAM Replacement, Disconnect the battery: adım 5, 3 resimden 1. HP EliteBook x360 830 G6 RAM Replacement, Disconnect the battery: adım 5, 3 resimden 2. HP EliteBook x360 830 G6 RAM Replacement, Disconnect the battery: adım 5, 3 resimden 3.
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 RAM Replacement, RAM: adım 6, 3 resimden 1. HP EliteBook x360 830 G6 RAM Replacement, RAM: adım 6, 3 resimden 2. HP EliteBook x360 830 G6 RAM Replacement, RAM: adım 6, 3 resimden 3.
    • Use the Phillips #0 screwdriver to remove the four 3 mm screws holding the RAM cover in place.
    • Pull up on the metal cover gently, it should make a slight noise signifying that it popped off.
    • Remove the metal cover completely revealing two sticks of RAM.
  7. HP EliteBook x360 830 G6 RAM Replacement: adım 7, 3 resimden 1. HP EliteBook x360 830 G6 RAM Replacement: adım 7, 3 resimden 2. HP EliteBook x360 830 G6 RAM Replacement: adım 7, 3 resimden 3.
    • Using your fingers gently pull the arms on the edges of the RAM stick away from the RAM to release it.
    • They should now be seated at an angled position.
    • Gently pull the RAM stick out of it socket.
    • Handle the RAM gently so you do not bend the socket pins.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Chasen Romo
85 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-2, Saknee Fall 2021 Gateway, Team 1-2, Saknee Fall 2021 üyesi
GCC-SAKNEE-F21S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 19
Son 30 gün: 102
Her zaman: 2,511
