Ana içeriğe geç
HP EliteBook x360 830 G7 Solid State Drive Replacement
Neye ihtiyacın var
  1. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: adım 1, 2 resimden 1. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: adım 1, 2 resimden 2.
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the metal shield covering the SSD: adım 2, 1 resimden 1.
    • Lift the metal shielding off of the solid state drive.
  3. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: adım 3, 3 resimden 1. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: adım 3, 3 resimden 2. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: adım 3, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the 4 mm screw that secures the SSD.
  4. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the SSD: adım 4, 1 resimden 1.
    • Gently pull the SSD free from the M.2 socket.
Sonuç
Emily Kaplan
217 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 90
Her zaman: 1,582
