Ana içeriğe geç
HP ElitePad 1000 G2 Motherboard Replacement
Neye ihtiyacın var
  1. HP ElitePad 1000 G2 Motherboard Replacement, Display: adım 1, 3 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement, Display: adım 1, 3 resimden 2. HP ElitePad 1000 G2 Motherboard Replacement, Display: adım 1, 3 resimden 3.
    • Before disassembling the tablet: make sure the tablet is off, disconnect the power cord from the tablet, and disconnect all external devices from the tablet.
    • Using a Phillips #00 screwdriver, remove the two Phillips PM 1.4×3.2mm screws located next to the charging port.
  2. HP ElitePad 1000 G2 Motherboard Replacement: adım 2, 3 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 2, 3 resimden 2. HP ElitePad 1000 G2 Motherboard Replacement: adım 2, 3 resimden 3.
    • Place the suction cup on the lower right corner of the tablet display glass, making sure to place the suction cup inside the edges of the border of the display glass.
    • Insert a plastic pick in between the display and the tablet case. Then use a plastic removal tool to separate the display further.
    • Pull on the suction cup while using the prying tool to separate the display from the tablet.
    • Gently lift the display from the tablet in order to avoid damaging the cables.
  3. HP ElitePad 1000 G2 Motherboard Replacement: adım 3, 3 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 3, 3 resimden 2. HP ElitePad 1000 G2 Motherboard Replacement: adım 3, 3 resimden 3.
    • To disconnect the cables, use the spudger tool to gently pull back on the black tab located on the side of the connector while gently pulling the cable.
    • Release the zero insertion force (ZIF) connector to which the TouchScreen cable is attached, and then disconnect the TouchScreen cable from the system board.
  4. HP ElitePad 1000 G2 Motherboard Replacement: adım 4, 2 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 4, 2 resimden 2.
    • Release the ZIF connector to which the display cable is attached, and then disconnect the display cable from the system board.
  5. HP ElitePad 1000 G2 Motherboard Replacement: adım 5, 2 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the display from the tablet.
  6. HP ElitePad 1000 G2 Motherboard Replacement, NFC Antenna: adım 6, 2 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement, NFC Antenna: adım 6, 2 resimden 2.
    • Locate the NFC antenna.
    • Release the ZIF connector to which the NFC antenna cable is attached.
    • To disconnect the cable, use the plastic prying tool to gently push on the tab located on the side of the connector.
  7. HP ElitePad 1000 G2 Motherboard Replacement: adım 7, 2 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 7, 2 resimden 2.
    • Detach the NFC antenna from the surface of the system board.
    • The NFC antenna is attached to the system board with double-sided adhesive.
    • Remove the NFC antenna.
  8. HP ElitePad 1000 G2 Motherboard Replacement, Power/Volume button: adım 8, 1 resimden 1.
    • Locate the power button board and attached ribbon cable.
    • Locate the volume button board.
  9. HP ElitePad 1000 G2 Motherboard Replacement: adım 9, 3 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 9, 3 resimden 2. HP ElitePad 1000 G2 Motherboard Replacement: adım 9, 3 resimden 3.
    • Disconnect the volume button board cable from the power button board.
    • Disconnect the left microphone cable from the power button board.
    • For both of these connectors, there's a thin seam in the middle. To disconnect, wedge your tool in between the seam and firmly, but carefully push.
  10. HP ElitePad 1000 G2 Motherboard Replacement: adım 10, 3 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 10, 3 resimden 2. HP ElitePad 1000 G2 Motherboard Replacement: adım 10, 3 resimden 3.
    • Lift the clear tape which is attached to the power button board cable and the motherboard.
    • Release the ZIF connector to which the power button board cable is attached.
    • Detach the power button board cable from the surface of the battery by pulling away from the connector.
    • The power button board cable is attached to the battery with double-sided adhesive.
  11. HP ElitePad 1000 G2 Motherboard Replacement: adım 11, 3 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 11, 3 resimden 2. HP ElitePad 1000 G2 Motherboard Replacement: adım 11, 3 resimden 3.
    • Remove the Phillips PM1.3×2.0mm broad head screw and the Phillips PM1.3×2.0mm screw that secure the power button board to the bottom cover.
    • Gently push upwards on the tab
  12. HP ElitePad 1000 G2 Motherboard Replacement: adım 12, 2 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 12, 2 resimden 2.
    • Remove the power button board and cable.
  13. HP ElitePad 1000 G2 Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the two Phillips PM1.5×2.0mm screws that secure the volume button board to the bottom cover.
  14. HP ElitePad 1000 G2 Motherboard Replacement: adım 14, 3 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 14, 3 resimden 2. HP ElitePad 1000 G2 Motherboard Replacement: adım 14, 3 resimden 3.
    • Remove the volume button board and cable.
  15. HP ElitePad 1000 G2 Motherboard Replacement, Audio Jack: adım 15, 1 resimden 1.
    • Locate the audio jack board.
  16. HP ElitePad 1000 G2 Motherboard Replacement: adım 16, 3 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 16, 3 resimden 2. HP ElitePad 1000 G2 Motherboard Replacement: adım 16, 3 resimden 3.
    • Disconnect audio jack board cable from the motherboard.
    • Remove the two Phillips PM 1.3x2.0mm screws that secure the audio jack board from the housing.
    • Remove the audio jack board.
  17. HP ElitePad 1000 G2 Motherboard Replacement, Battery: adım 17, 1 resimden 1.
    • Locate the power button board ribbon cable.
    • Locate the battery to motherboard connector.
  18. HP ElitePad 1000 G2 Motherboard Replacement: adım 18, 3 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 18, 3 resimden 2. HP ElitePad 1000 G2 Motherboard Replacement: adım 18, 3 resimden 3.
    • Lift the clear tape attached to the power button board ribbon cable.
    • Disconnect the ZIF connector by using a plastic removal tool to gently pull up on the black tab.
    • Lift the power button board ribbon cable up and away so that it doesn't get in the way of the battery during removal.
  19. HP ElitePad 1000 G2 Motherboard Replacement: adım 19, 2 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 19, 2 resimden 2.
    • Disconnect the battery to system board connector by pushing gently on it with a plastic pry tool and then pull it away from the system board.
  20. HP ElitePad 1000 G2 Motherboard Replacement: adım 20, 1 resimden 1.
    • Using a philips 00 screw driver take out the six Phillips PM1.3×2.0mm screws
  21. HP ElitePad 1000 G2 Motherboard Replacement: adım 21, 2 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 21, 2 resimden 2.
    • Carefully lift the battery away from the bottom cover.
  22. HP ElitePad 1000 G2 Motherboard Replacement, Motherboard: adım 22, 2 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement, Motherboard: adım 22, 2 resimden 2.
    • Release the webcam from the housing.
    • Remove the six Phillips PM 1.3 x 2.0mm screws that secure the board to the bottom cover.
  23. HP ElitePad 1000 G2 Motherboard Replacement: adım 23, 3 resimden 1. HP ElitePad 1000 G2 Motherboard Replacement: adım 23, 3 resimden 2. HP ElitePad 1000 G2 Motherboard Replacement: adım 23, 3 resimden 3.
    • Carefully lift the mother board from the top by the camera and reveal the back side of the board.
    • With the backside of the motherboard exposed remove the two Phillips 1.3 mm screws.
    • Disconnect the ribbon connector on the back of the board.
    • Remove ribbon connector that connects to the WLAN module.
    • Remove the motherboard.
Sonuç
Bir Yorum
I am looking for the hard drive in the tablet I want upgrade the capacity of the
abuhamed choaib - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 1,715
