Giriş
The HP ElitePad 1000 G2’s power and volume buttons, just like any other hardware, are subject to wear and tear. If after troubleshooting you determined that you aren’t having software issues and a replacement is necessary, this guide will walk you through the replacement process.
Neye ihtiyacın var
Using a Phillips #00 screwdriver, remove the two Phillips PM 1.4×3.2mm screws located next to the charging port.
Place the suction cup on the lower right corner of the tablet display glass, making sure to place the suction cup inside the edges of the border of the display glass.
Insert a plastic pick in between the display and the tablet case. Then use a plastic removal tool to separate the display further.
Pull on the suction cup while using the prying tool to separate the display from the tablet.
Locate the NFC antenna.
Release the ZIF connector to which the NFC antenna cable is attached.
Locate the power button board and attached ribbon cable.
Locate the volume button board.
