Ana içeriğe geç
HP Elitebook 840 G1 Battery Replacement
Ashley Williams
Ashley Williams ve 6 diğer katkıda bulunanlar
En son May 23, 2021 tarihinde güncellendi
2 dakika
Çok kolay
Replace dead or dying battery to solve for laptop powering off right away or quickly when unplugged
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. HP Elitebook 840 G1 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Slide the latch, to the right, away from the lock symbol.
    • Slide the cover away from the latch to remove it.
    Slide to your "other left", on this screen it would be to the right, to slide open the cover
    petunia8107 - Yanıt
    l’expression “Détachez le cache du loquet pour le retirer “ est ambigüe et source d’erreur, elle donne à penser qu’il faut retirer un “cache” qui serait sur le loquet.
    Ce qu’il faut c’est détacher le cache (la grande plaque où il y a la logo bleu) de la partie fixe sur laquelle se trouve le loquet. Pour ça il faut glisser une lame fine dans la fente entre le cache et la partie fixe.
    merci pour le tutoriel.
    Philippe Fayolle - Yanıt
    Bonjour Philippe,
    Vous avez bien raison ! J’ai adapté la traduction. Merci pour l’observation ! N’hésitez pas à corriger le texte la prochaine fois. Vous trouverez l’interface de traduction en cliquant sur Traduire en haut à droite de l’étape.
    Bonne réparation !
    Claire Miesch -
  2. HP Elitebook 840 G1 Battery Replacement: adım 2, 1 resimden 1.
    • Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
    • The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
  3. HP Elitebook 840 G1 Battery Replacement: adım 3, 1 resimden 1.
    • Battery should easily be lifted up and out.
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
Ashley Williams
2.419 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-3, Blackwell Fall 2015 USF Tampa, Team 5-3, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S5G3
4 Üyeler
19 adet Kılavuz yazıldı
2 Yorum
Where do I buy another battery and how long does it last on the laptop? 4hr or more?
Vikshay Vuthavadoo - Yanıt
Passt auch für HP Elitebook 850 G2.
Die Anleitung und der Ersatzakku konnten auch bei einem HP Elitebook 850 G2 (Bezeichnung lt. Systeminfo des Notebooks) verwendet werden, das der Akku exakt der gleiche war (HP CM03)
Raller - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 35
Son 30 gün: 257
Her zaman: 79,404
