Ana içeriğe geç
HP Elitebook 8460p RAM (Random Access Memory) Replacement
Neye ihtiyacın var
  1. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Battery: adım 1, 1 resimden 1.
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
    what if it does not work,what does that mean?
    julia melrose - Yanıt
  2. HP Elitebook 8460p RAM (Random Access Memory) Replacement: adım 2, 1 resimden 1.
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Back Panel: adım 3, 1 resimden 1.
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p RAM (Random Access Memory) Replacement: adım 4, 1 resimden 1.
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): adım 5, 3 resimden 1. HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): adım 5, 3 resimden 2. HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): adım 5, 3 resimden 3.
    • Attach ESD strap around your wrist and to a ground.
    • Using both thumbs, locate the two metal clips and pull them apart, allowing the RAM chip to pop upwards.
  6. HP Elitebook 8460p RAM (Random Access Memory) Replacement: adım 6, 2 resimden 1. HP Elitebook 8460p RAM (Random Access Memory) Replacement: adım 6, 2 resimden 2.
    • Pull the RAM chip straight out and repeat for the second chip.
    • If installing new RAM chip(s), seat the chip firmly in the RAM slot and push down until the metal clips snap in place.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Great job thanks
Charles Tighe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 46
Her zaman: 2,174
