Ana içeriğe geç
HP Elitebook 8570w Display Replacement
MJ Routh
MJ Routh ve 2 diğer katkıda bulunanlar
En son December 21, 2017 tarihinde güncellendi
15 dakika
Orta
This replacement guide will show you how to disconnect the display from your HP EliteBook 8570w. It consists of 7 moderately difficult steps that should guide you successfully.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. HP Elitebook 8570w Display Replacement, Display: adım 1, 3 resimden 1. HP Elitebook 8570w Display Replacement, Display: adım 1, 3 resimden 2. HP Elitebook 8570w Display Replacement, Display: adım 1, 3 resimden 3.
    • With the computer opened, locate the square buttons on both bottom corners of the display.
    • Using a tool or finger, wedge the squares off revealing a screw on each corner.
  2. HP Elitebook 8570w Display Replacement: adım 2, 1 resimden 1.
    • Use a T9 screwdriver to unscrew both 0.4mm Torx screws.
  3. HP Elitebook 8570w Display Replacement: adım 3, 2 resimden 1. HP Elitebook 8570w Display Replacement: adım 3, 2 resimden 2.
    • Use an opening tool or spudger to peel back the outer rim of the display.
    • Continue to peel back the entire rim.
  4. HP Elitebook 8570w Display Replacement: adım 4, 1 resimden 1.
    • Unscrew ONLY the bottom 0.8mm T9 Torx screw on both sides of the display.
  5. HP Elitebook 8570w Display Replacement: adım 5, 3 resimden 1. HP Elitebook 8570w Display Replacement: adım 5, 3 resimden 2. HP Elitebook 8570w Display Replacement: adım 5, 3 resimden 3.
    • Now locate the two screws on each side at the bottom of the display.
    • TOP screw: unscrew partially.
    • BOTTOM screw: completely unscrew and set to the side.
    • Complete on both sides of display.
    • Carefully separate the display from the top cover.
    • Be sure to not let the top cover fall back
  6. HP Elitebook 8570w Display Replacement: adım 6, 2 resimden 1. HP Elitebook 8570w Display Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #00 screwdriver to unscrew all four 0.8 mm screws from the left side of the display frame. Repeat for the right side.
    • Push the metal plates/rods that were attached to the display towards the top cover.
    • The display should be completely free of the top cover and able to lay flat on the keyboard (refer to photo #2).
  7. HP Elitebook 8570w Display Replacement: adım 7, 3 resimden 1. HP Elitebook 8570w Display Replacement: adım 7, 3 resimden 2. HP Elitebook 8570w Display Replacement: adım 7, 3 resimden 3.
    • With the display laying on the keyboard, locate the black square panel marked in the photo.
    • Grab the side marked in photo #2 and pull it towards you peeling off the surrounding tape and releasing it from the actual display board.
    • This will then remove the connection between the display and the top cover.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
MJ Routh
465 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team S8-G5, Johnson Fall 2017 Baylor, Team S8-G5, Johnson Fall 2017 üyesi
BU-JOHNSON-F17S8G5
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
this guide is really bad, dangerous and should be removed !
at step 3 you crack and kill the existing display. If it was still somewhat working before now you are assured it is completely dead !
adrenochrome - Yanıt
agreed, step 3 should use the opening tool on a top corner of the bezel, not against the screen. you just screwed up the screen if it worked at all
Hidden Djinn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 37
Her zaman: 3,844
