HP Elitebook 8570w Hard Drive Replacement
Giriş
1. adıma gitThis replacement guide will help you disconnect the hard drive from your HP EliteBook 8570w in order to replace it with a new/different hard drive. It consists of 6 relatively easy steps that should guide you successfully.
Neye ihtiyacın var
Tamir Setleri
Bu kitler, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
To begin, you will need to remove the battery by sliding the left slider (red) to the left.
Push the battery away from you to release it.
Then, use the right slider to remove the computer's backing (shown in image)
Slide the backing towards you to remove it.
5 farklı kişi bu kılavuzu tamamladı.
