Ana içeriğe geç
HP Elitebook Folio 9470m Hard Drive Replacement
Kenneth Bowers
Kenneth Bowers ve 8 diğer katkıda bulunanlar
En son January 3, 2024 tarihinde güncellendi
25 dakika
Orta
This guide will teach you how to replace a full or faulty hard drive on your HP Elitebook Folio 9470m.
The hard drive is the storage of your device; a faulty hard drive could cause crashes, long load times, excessive noise, and even loss of files.
Hard drives are very sensitive to sudden impacts, any impact could cause scratches on the disk inside the hard drive causing data loss.
Be sure if you have any important files on the hard drive to back them up before beginning the replacement. Make sure that the device is off and disconnected from any external power source before beginning.
Neye ihtiyacın var
Tamir Setleri
Bu kitler, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. HP Elitebook Folio 9470m Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. HP Elitebook Folio 9470m Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Hard Drive Replacement: adım 2, 2 resimden 1. HP Elitebook Folio 9470m Hard Drive Replacement: adım 2, 2 resimden 2.
    • Remove battery using This guide.
  3. HP Elitebook Folio 9470m Hard Drive Replacement: adım 3, 3 resimden 1. HP Elitebook Folio 9470m Hard Drive Replacement: adım 3, 3 resimden 2. HP Elitebook Folio 9470m Hard Drive Replacement: adım 3, 3 resimden 3.
    • Unscrew the 2 Phillips screws.
    • Slide the cover to the left, then remove the cover.
  4. HP Elitebook Folio 9470m Hard Drive Replacement: adım 4, 1 resimden 1.
    • Unscrew the 4 Phillips screws securing the hard drive.
  5. HP Elitebook Folio 9470m Hard Drive Replacement: adım 5, 1 resimden 1.
    • Remove by gently pulling up on the tab and out.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Kenneth Bowers
1.432 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 UMass Dartmouth, Team S1-G1, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S1G1
4 Üyeler
19 adet Kılavuz yazıldı
2 Yorum
Pls I have lost my battery can u help me get another one for my lap please
Hw much will it cost
kingsleysenuduku - Yanıt
A bit late to the Party but you can find the battery on the main-site of the HP Elitebook Folio 9470m under the section «Parts»
RudiDerHirsch -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 32
Son 30 gün: 71
Her zaman: 9,593
