Ana içeriğe geç
HP Elitebook x360 1040 G5 Battery Replacement
Neye ihtiyacın var
  1. HP Elitebook x360 1040 G5 Battery Replacement, Lower Case: adım 1, 2 resimden 1. HP Elitebook x360 1040 G5 Battery Replacement, Lower Case: adım 1, 2 resimden 2.
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Battery Replacement: adım 2, 2 resimden 1. HP Elitebook x360 1040 G5 Battery Replacement: adım 2, 2 resimden 2.
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Battery Replacement, Battery: adım 3, 2 resimden 1. HP Elitebook x360 1040 G5 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Battery Replacement: adım 4, 3 resimden 1. HP Elitebook x360 1040 G5 Battery Replacement: adım 4, 3 resimden 2. HP Elitebook x360 1040 G5 Battery Replacement: adım 4, 3 resimden 3.
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Corey Agena
794 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G4, Maness Spring 2019 Cal Poly, Team S1-G4, Maness Spring 2019 üyesi
CPSU-MANESS-S19S1G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 45
Her zaman: 2,151
