Ana içeriğe geç
HP Envy 5660 Printhead Replacement
Neye ihtiyacın var
  1. HP Envy 5660 Printhead Replacement, Printhead: adım 1, 1 resimden 1.
    • Open the printer so that the underside of the scanner is showing.
  2. HP Envy 5660 Printhead Replacement: adım 2, 1 resimden 1.
    • Unscrew the black 11.5 mm screw closest to the front right corner using a T10 screw bit.
  3. HP Envy 5660 Printhead Replacement: adım 3, 1 resimden 1.
    • Remove right side of the printer using a plastic opening tool or metal spudger.
    This is the wrong side of the printer. This grants access to a PCB and ribbon cables.
    Thomas John - Yanıt
  4. HP Envy 5660 Printhead Replacement: adım 4, 1 resimden 1.
    • Remove spring from the side of the print head rail using a metal spudger.
    And remove the E clip. Your instructions come up short.
    Thomas John - Yanıt
  5. HP Envy 5660 Printhead Replacement: adım 5, 2 resimden 1. HP Envy 5660 Printhead Replacement: adım 5, 2 resimden 2.
    • Push the metal rail the print head rests on inwards to remove it from its bearings.
    You need to remove the E clip first.
    Thomas John - Yanıt
  6. HP Envy 5660 Printhead Replacement: adım 6, 1 resimden 1.
    • Remove the belt from the back of the print head using a metal spudger.
    One needs to remove the print head from the drive gears. These are located under the plastic cover in the background.
    Still zero mention of a ribbon cable.
    Thomas John - Yanıt
  7. HP Envy 5660 Printhead Replacement: adım 7, 1 resimden 1.
    • Remove the print head from the metal rail by sliding it off the rail.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Steakley
781 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G6, Livingston Winter 2018 Cal Poly, Team S1-G6, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S1G6
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
I wouldn't recommend this guide to anyone without prior experience as it's non-thorough and missing many steps. Started with a clogged printhead; finished with a torn ribbon cable and a couple other new damages.
Ryan Steakley's Dad - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 22
Son 30 gün: 174
Her zaman: 5,654
