HP Envy 5660 Scanner Glass Replacement
Giriş
1. adıma gitThe scanner glass for the HP Envy 5660 may receive cracks over time. This guide will help the user replace the scanner glass.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Remove an additional three 11.5 mm torx head screws in the same plane as step #4 photo, but near the hinges. This allows the cover hinges to be raised a bit for easier access to the screws removed in step #7. It also makes it easier to remove and reinstall the side cover.
My scanner glass was not broken, but inside surface had a dirty haze that was effecting my scans and needed cleaning. Thanks, I was ready to buy a new scanner.
