Ana içeriğe geç
HP Envy x360 m6-aq105dx RAM Replacement
Cory Smith
Cory Smith ve 4 diğer katkıda bulunanlar
En son June 3, 2020 tarihinde güncellendi
15 - 20 dakika
Orta
Daha iyi giriş
RAM stands for Random Access Memory. RAM temporarily stores memory. This guide will instruct on how to replace your computer’s RAM.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. HP Envy x360 m6-aq105dx RAM Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx RAM Replacement: adım 2, 1 resimden 1.
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Attach the grounding bracelet's clip to the frame of the laptop then put on the grounding bracelet.
    • Lift up the RAM cover panel and remove it from the device.
  4. HP Envy x360 m6-aq105dx RAM Replacement: adım 4, 2 resimden 1. HP Envy x360 m6-aq105dx RAM Replacement: adım 4, 2 resimden 2.
    • Pull away the levers away from each other to disconnect the RAM stick. Repeat this step for any subsequent sticks of RAM.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 22
Her zaman: 352
