Ana içeriğe geç
HP Mini 1000 Speaker Grill Replacement
Neye ihtiyacın var
  1. HP Mini 1000 Speaker Grill Replacement, Battery: adım 1, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement, Battery: adım 1, 2 resimden 2.
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. HP Mini 1000 Speaker Grill Replacement: adım 2, 1 resimden 1.
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
  3. HP Mini 1000 Speaker Grill Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the following two screws:
    • One 6 mm Phillips screw
    • One 4 mm Phillips screw
  4. HP Mini 1000 Speaker Grill Replacement: adım 4, 3 resimden 1. HP Mini 1000 Speaker Grill Replacement: adım 4, 3 resimden 2. HP Mini 1000 Speaker Grill Replacement: adım 4, 3 resimden 3.
    • To facilitate the removal of the keyboard, it is recommended to push the keyboard outwards with one hand through the opening (highlighted in the third picture) located on the backside of the Mini 1000.
    • While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you.
    • Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
  5. HP Mini 1000 Speaker Grill Replacement: adım 5, 1 resimden 1.
    • Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
  6. HP Mini 1000 Speaker Grill Replacement: adım 6, 1 resimden 1.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the cable out of its socket and remove the keyboard.
  7. HP Mini 1000 Speaker Grill Replacement, Hard Drive: adım 7, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement, Hard Drive: adım 7, 2 resimden 2.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
    • Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
  8. HP Mini 1000 Speaker Grill Replacement: adım 8, 1 resimden 1.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
  9. HP Mini 1000 Speaker Grill Replacement: adım 9, 1 resimden 1.
    • Remove the two 4.5 mm Phillips screws securing the hard drive to the lower case.
  10. HP Mini 1000 Speaker Grill Replacement: adım 10, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement: adım 10, 2 resimden 2.
    • Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
  11. HP Mini 1000 Speaker Grill Replacement, Upper Case: adım 11, 1 resimden 1.
    • Using the sharp tip of a spudger, pry and remove the four plastic screw covers from the underside of the HP Mini 1000.
    • There are three different variations of the covers:
    • The two bottom covers are short in height and are notched to prevent incorrect insertion
    • The upper right cover is taller in height and is notched.
    • The upper left cover is taller in height and is not notched.
  12. HP Mini 1000 Speaker Grill Replacement: adım 12, 1 resimden 1.
    • Remove the four 7 mm Phillips screws that secure the upper case to the lower case.
  13. HP Mini 1000 Speaker Grill Replacement: adım 13, 1 resimden 1.
    • Flip the computer over and open the display.
    • Remove the two 4.5 mm Phillips screws securing the upper case to the lower case.
  14. HP Mini 1000 Speaker Grill Replacement: adım 14, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement: adım 14, 2 resimden 2.
    • Wedge the flat end of a spudger in between the upper case and lower case near the bottom right corner of the display.
    • Carefully pry and rock the spudger upwards to create a small gap between the upper case and lower case.
    • Continue the previously described motion along the right edge of the upper case to release the clips securing the upper case to the lower case.
  15. HP Mini 1000 Speaker Grill Replacement: adım 15, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement: adım 15, 2 resimden 2.
    • Repeat the same procedure as mentioned in the previous step to release the clips along the left side of the upper case.
  16. HP Mini 1000 Speaker Grill Replacement: adım 16, 1 resimden 1.
    • Grasp the upper case and carefully lift it slightly upwards, freeing it from any remaining clips.
    • The upper case is still attached via the TouchPad ribbon cable that is connected to the motherboard. Do not remove it completely just yet.
  17. HP Mini 1000 Speaker Grill Replacement: adım 17, 1 resimden 1.
    • Lay the upper case on top of the upper portion of the motherboard.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the TouchPad cable ZIF socket.
    • Pull the TouchPad ribbon cable out of its socket.
    • Remove the upper case from the HP Mini 1000.
  18. HP Mini 1000 Speaker Grill Replacement, Wi-Fi Board: adım 18, 1 resimden 1.
    • If present, peel the sticker up off the top of the Wi-Fi board to reveal the Wi-Fi antenna connectors.
  19. HP Mini 1000 Speaker Grill Replacement: adım 19, 3 resimden 1. HP Mini 1000 Speaker Grill Replacement: adım 19, 3 resimden 2. HP Mini 1000 Speaker Grill Replacement: adım 19, 3 resimden 3.
    • Pry the Wi-Fi antenna connectors (2 total) up off the Wi-Fi board.
    • During reassembly, remember to correctly connect the antenna cables to their respective terminals. The green labeled antenna is connected to the "MAIN" terminal and the white labeled antenna is connected to the "AUX" terminal.
  20. HP Mini 1000 Speaker Grill Replacement: adım 20, 1 resimden 1.
    • Remove the single 3 mm Phillips screw securing Wi-Fi board to the motherboard.
  21. HP Mini 1000 Speaker Grill Replacement: adım 21, 1 resimden 1.
    • Upon removing the Phillips screw that secures the Wi-Fi board to the motherboard, the Wi-Fi board should pop up from its top side nearest the antenna sockets.
    • Grasp the Wi-Fi board and lift it straight away from its socket on the motherboard.
  22. HP Mini 1000 Speaker Grill Replacement, Heat Sink: adım 22, 1 resimden 1.
    • Remove the two 2.5 mm Phillips screws securing the heat sink to the motherboard.
  23. HP Mini 1000 Speaker Grill Replacement: adım 23, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement: adım 23, 2 resimden 2.
    • Carefully lift the heat sink off the face of the motherboard and de-route the curved section from next to the fan.
    • Before reinstalling the heat sink, be sure to apply a new layer of thermal paste to the CPU. We have a thermal paste guide that makes it easy.
    • Only apply a new layer of thermal paste to the face of the CPU. The CPU is the large processor located closest to the fan.
  24. HP Mini 1000 Speaker Grill Replacement, Display Assembly: adım 24, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement, Display Assembly: adım 24, 2 resimden 2.
    • If present, carefully remove the large piece of black adhesive film covering the Wi-Fi board.
  25. HP Mini 1000 Speaker Grill Replacement: adım 25, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement: adım 25, 2 resimden 2.
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the Wi-Fi board.
  26. HP Mini 1000 Speaker Grill Replacement: adım 26, 1 resimden 1.
    • If present, remove the pieces of tape securing the Wi-Fi antenna cables to the upper case.
  27. HP Mini 1000 Speaker Grill Replacement: adım 27, 1 resimden 1.
    • If present, carefully remove the large piece of black adhesive film from the area surrounding the fan.
  28. HP Mini 1000 Speaker Grill Replacement: adım 28, 1 resimden 1.
    • If present, remove the several pieces of black cloth tape securing the cables to the upper case near the fan.
  29. HP Mini 1000 Speaker Grill Replacement: adım 29, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement: adım 29, 2 resimden 2.
    • Use the flat end of a spudger to disconnect each of the following connectors from their respective sockets:
    • Speaker cable
    • Microphone cable
    • Fan cable
    • Power cable
    • Display data cable
    • Push the connectors out of their sockets parallel to the face of the motherboard toward the display assembly. Do not lift up on the cables as you disconnect them, especially the display data cable, as their sockets may break off the motherboard.
  30. HP Mini 1000 Speaker Grill Replacement: adım 30, 1 resimden 1.
    • If present, peel back the strip of white cloth tape highlighted in red to reveal a display screw.
  31. HP Mini 1000 Speaker Grill Replacement: adım 31, 1 resimden 1.
    • Remove the single 5 mm Phillips screw securing the right display hinge to the lower case.
  32. HP Mini 1000 Speaker Grill Replacement: adım 32, 1 resimden 1.
    • Remove the two 5 mm Phillips screws securing the left display hinge to the lower case.
  33. HP Mini 1000 Speaker Grill Replacement: adım 33, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement: adım 33, 2 resimden 2.
    • Lift the display out of the lower case, minding any cables that may get caught.
  34. HP Mini 1000 Speaker Grill Replacement, Speaker Grill: adım 34, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement, Speaker Grill: adım 34, 2 resimden 2.
    • Use the edge of a plastic opening tool to pry the left side of the speaker grill away from the display assembly.
    • Be careful not to apply too much pressure to the display glass.
  35. HP Mini 1000 Speaker Grill Replacement: adım 35, 1 resimden 1.
    • Continue prying along the center of the speaker grill.
  36. HP Mini 1000 Speaker Grill Replacement: adım 36, 2 resimden 1. HP Mini 1000 Speaker Grill Replacement: adım 36, 2 resimden 2.
    • Pry the right side of the speaker grill away from the display assembly.
  37. HP Mini 1000 Speaker Grill Replacement: adım 37, 1 resimden 1.
    • Remove the speaker grill.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 3,266
