Ana içeriğe geç
HP Mini 210 CMOS Battery Replacement
Heather Freed
Heather Freed ve 8 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
10 - 15 dakika
Kolay
Eksik Adımlar
Yanlış Araçlar
If the system clock or the BIOS (Basic Input/Output System) settings reset when the netbook is turned off, the CMOS (Complementary Metal-Oxide Semiconductor) battery may need to be replaced.
The CMOS battery should be replaced with a 3-volt 2032-size coin battery.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. HP Mini 210 CMOS Battery Replacement, Battery: adım 1, 2 resimden 1. HP Mini 210 CMOS Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 CMOS Battery Replacement: adım 2, 1 resimden 1.
    • Slide the battery out from the netbook.
  3. HP Mini 210 CMOS Battery Replacement, Disassembling HP Mini 210 Back Case: adım 3, 1 resimden 1.
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 CMOS Battery Replacement: adım 4, 1 resimden 1.
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 CMOS Battery Replacement: adım 5, 1 resimden 1.
    • Pull the back case off from the front edge.
  6. HP Mini 210 CMOS Battery Replacement, CMOS Battery: adım 6, 1 resimden 1.
    • Cut one side of the black adhesive ribbon on top of the CMOS battery with a utility blade.
    • Be careful not to scratch or damage the battery or netbook, and be sure to keep your fingers out of the way!
  7. HP Mini 210 CMOS Battery Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Slowly peel back the black adhesive ribbon with tweezers.
  8. HP Mini 210 CMOS Battery Replacement: adım 8, 1 resimden 1.
    • Pry the CMOS battery out with a plastic opening tool.
  9. HP Mini 210 CMOS Battery Replacement: adım 9, 1 resimden 1.
    • Pop the CMOS battery out.
    • When reinstalling, insert the battery back into the slot with the positive terminal facing up.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Heather Freed
723 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G17
3 Üyeler
2Kılavuz Yorumları
after need CMOS reset. Screen is black. Is there an easy way on my HP Mini 210?
Carl Louviere - Yanıt
Very good tut. Now my HP Mini 210 can get the right time xD
Byte Core - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 52
Her zaman: 16,034
