HP Officejet 5740 Disassembly
Giriş
1. adıma gitProcedure to disassemble HP Officejet 5740 printer
I wrote this down as much for me as anybody else. Kind of like bread crumbs in the forest. It helps to not forget a step.
I found nothing on the net on disassembling or repairing this machine.
My wife had noticed that the printer sounded like it was laboring. Gear noise. I have had a number of printers apart. Every time I do I am amazed at how increasingly flimsy they are getting. When I did get it down to the chassis the shaft with the large paper feed rolls seemed to be misaligned. I tweeked it over so it didn't rub. On reassembly, voila gear noise seemed to be gone. Fingers crossed it works better than before.
I have no pictures. You'll have to use your imagination
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
It is assumed that you have unplugged the data cables and using the soft ware of the printer moved the printer head away from the parked position prior to disconnecting the power plug so it can't return to the parked position.
Looking at the printer from the right side and focusing on the pin which the latch is hooked to on the cover, notice that there is a tiny space in the lower left-hand area of the connection between the pin and the hook. Insert screwdriver into that space and turn the screwdriver clockwise. Hook pops off the pin toward the front of the machine.
The right side is held in place by 2 screws and a couple of lugs front and back. The rear screw holding the right side cover is hidden behind and under the J hook latch coming up from below. Take your flash light and find the screw down in its hole. Otherwise you will pry like hell and break the loop which attaches the side to the chassis.
Remove those two screws. Then there is a lug up under the control panel which needs to be pried loose. With a little finagling the cover should wiggle loose. There are two fixed lugs visible from under the machine. DO NOT try to pry on them as they hold the side on and are not made to be a latch. The side will roll back from the top the lugs pop up
To get the inner cover off the machine you must remove the screw holding the spring tensioner tape to the lid. Do this by loosening the screw on the lid while reaching down by the ink sump and gently taking the tension off the tape by pulling on the spring. Might be easier with two sets of hands.
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
mi hp no reconoce un cartucho y aunque lo reemplazo sigue diciendo que esta dañado
