Ana içeriğe geç
HP Pavilion 14 Notebook Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion 14 Notebook Battery Replacement, Remove Enclosure: adım 1, 1 resimden 1.
    • Unscrew the 5 P1 Philips screws (2 under the rubbers). You can esaily follow: HP official video to Remove the Base Enclosure
    • Once you pull up the sides of the cover (e.g. with a pick). You will feel it is still attached in the middle. You can squeeze your hand under the enclosure and push from the middle to liberate a clip in the middle of the enclosure. Pulling directly from the sides feels like the cover will break.
    • If you are not sure of the model of the computer/battery. you can do this step to check the battery model before buying it and then close it again doing the inverse.
  2. HP Pavilion 14 Notebook Battery Replacement, Replace Battery: adım 2, 2 resimden 1. HP Pavilion 14 Notebook Battery Replacement, Replace Battery: adım 2, 2 resimden 2.
    • You can check the battery model (top-left of the battery), for our case HT03XL, with this reference you will be able to get the propper replacement.
    • If you have the replacement you can unscrew the 5 P1 Philips screws. The top part will have the connector you will need to disconnect to remove the battery. You can follow HP official video to remove the battery
    • Connect the new battery and screw again the 5 screws.
Sonuç
To reassemble the enclosure, clip it again and screw again the 5 screws (follow Step 1 instructions in reverse order).
Bir başkası bu kılavuzu tamamladı.
Oriol CN
125 İtibar
1 Kılavuz yazıldı
Bir Yorum
Nice explanation about the disassemble the hp notebook laptop. And replace the original battery replacement hp guide
Mahima Singh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 50
Son 30 gün: 220
Her zaman: 2,095
