Ana içeriğe geç
HP Pavilion 14-cf0014dx Daughterboard Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-cf0014dx Daughterboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Daughterboard Replacement: adım 2, 1 resimden 1.
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Daughterboard Replacement, Battery: adım 3, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Daughterboard Replacement: adım 4, 1 resimden 1.
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Daughterboard Replacement, Daughterboard: adım 5, 1 resimden 1.
    • Remove the two 6.7 mm screws with a Phillips #0 screwdriver.
  6. HP Pavilion 14-cf0014dx Daughterboard Replacement: adım 6, 2 resimden 1. HP Pavilion 14-cf0014dx Daughterboard Replacement: adım 6, 2 resimden 2.
    • Unlock the ZIF connector with the tip of the spudger.
    • Remove the ribbon cable.
  7. HP Pavilion 14-cf0014dx Daughterboard Replacement: adım 7, 1 resimden 1.
    • Remove the daughterboard with a pair of tweezers.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Angel S
205 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 114
